Gadgets - Customize
  1. Posts : 27
    Windows 7 Pro 32bit
    scoopeeedoo said:
    Soul02 :
    I guess you did select well ALL the files before re-packing...?
    Ok... ive found what you mean, done what you said, and still its not working below is how i did it, just like you said! from pic 1 to 5.
    Pic1: the folder itself.
    Pic2: selected all files in the folder and went to folder options.
    Pic3: i beleive the one you mean is the one which ive put the arrow there?
    Pic4: renamed the file to .gadget in 7zip.
    Pic5: pressed ok! it did it... but then pressed install and i get: 'this is not a valid gadget package'
    Now in Pic3: do i need to restart computer for this? i did uncheck the 1st box at the top like you have done, though that didnt work i tried the other 2 below it also! still nothing ...
    Sorry for all this trouble! lol
    Attached Thumbnails Attached Thumbnails Gadgets - Customize-help1.jpg   Gadgets - Customize-help2.jpg   Gadgets - Customize-help3.jpg   Gadgets - Customize-help4.jpg   Gadgets - Customize-help5.jpg
  2. Posts : 339
    7Home64
    Soul02 said:
    scoopeeedoo said:
    Soul02 :
    Really no problem!!! We are gonna fix that !!! Sorry for slow response, i just came back from work and i think we've just missed ourselves for a couple of minutes...
    So, first, there's no need to select anything to go in the "folder options". They are general options, which means that if you do something in it, it's for all the files in your computer. Just open your explorer, go to the options and uncheck the options i've marked in the attached image below (i capt' your own image...), then you can leave the "folder options", next steps are out of it...
    Second : i see that your folder (the one which contains all the files shown in pic 1) is called "MyGadget.gadget"; it must be named only "MyGadget" (see my capt')
    Third : in your pic 4, i see a window which has not to be..., all you have to do is select all files of your pic 1, then right clic on one of the files (this will open the contextual menu), then slide your mouse on "7zip", this will open a new menu, then left clic on "add to MyGadget.zip" (i join the corresponding pic of my tuto). This will make a zip archive named "MyGadget.zip" (it will appears just between "gadget.xml" and "settings.html" in the files shown in your pic 1). This the file you have to rename, just select the "zip" and write "gadget"
    Don't worry, i stay tuned for more info if needed...!
    Good luck...
    EDIT : thanks for your observations, they allow me to shape my tuto...
    Attached Thumbnails Attached Thumbnails Gadgets - Customize-1.jpg   Gadgets - Customize-2.jpg   Gadgets - Customize-14.jpg
  3. Posts : 27
    Windows 7 Pro 32bit
       #12
    hehe i done it! thanks so much... the problem i was doing was, i didnt know i had to make it to a .zip file first! THEN rename that one to a .gadget file! haha... ill post on here soon as ive made a new and better one! thanks again man! 5*
  4. Posts : 339
    7Home64
    My pleasure! Glad you solve the prob'... I hope to see that soon!!!
  5. Posts : 27
    Windows 7 Pro 32bit
       #14
    Ok update! here is the first ... im really just testing but im thinking now to add my own touches, like some new fetures etc, ideas please everyone??? lol
    Gonna add a few versions too, game, stars, cars, etc ...
    Thx again, let me know what you think
    Edit: released 2 versions of it ver1 is the all black with some tweaks! and ver2
    is the blue tattoo design one with alot of tweaks!
    Id love to know how to put in a core temp app on it! and also a backgroud change option if anyone got any ideas on how? thanks...
    Attached Thumbnails Attached Thumbnails Gadgets - Customize-pic2.jpg   Gadgets - Customize-pic3.jpg
    Gadgets - Customize Attached Files
  6. Posts : 339
    7Home64
       #15
    According to me, really much smarter!
    Good work, Soul02!
  7. Posts : 339
    7Home64
       #16
    Please remember what i said in the tuto :
    You are not allowed to share customized gadget WITHOUT the owner's permission!!!
    Adding more options means that you must be able to make programmation... The subject here is to make a gadget closer to your own style, for your own use, if you need more, than learn how to make a gadget (from a to z) by yourself...
    Maybe this will help you : create your own windows gadget
    As you will can see, this is not a simple job, so, PLEASE, respect the author's work!!!
    Generaly, you can find links to the creator in the gadget's options or in the inside files (like a "read me" file, for exemple)
  8. Posts : 27
    Windows 7 Pro 32bit
       #17
    Adding more options means that you must be able to make programmation... The subject here is to make a gadget closer to your own style, if you need more, than learn how to make a gadget (from a to z) by yourself...
    Yep i know what you mean mate, ill not change anything untill ive spoken to the right guy whatever, though ive only changed the style its not the gadget itself!
    I have sent an email asking about weather i can change stuff etc and waiting for a reply! ... for now only the style though! :)
  9. Posts : 42
    Hey sir TS~
    What is your theme?
    I love the transparency lol
  10. Posts : 339
    7Home64
       #19
    zxcvbasdfg said:
    Hey sir TS~
    What is your theme?
    Hi!
    If you're talkin' of the theme in the tuto, it is "Meridian" for Windowblinds7
