How to Remove Windows Explorer Toolbar in Windows 7
InformationIn windows 7 Microsoft implemented a new toolbar in Windows Explorer. It has options like: Organize, Share with, Burn, New Folder. Do you want to get rid of this for good? This is how.
NoteIf you do this you will not be able to access any of the features that are on this bar, that includes changing which panes are up. You can however use these tutorials registry edits to turn them on or off:
To use custom themes after removing the explorer toolbar, you will have to extract the file to:
C:\Windows\Resources\Themes\"Custom Theme"\Shell\NormalColor
OPTION ONETo Remove Windows Explorer Toolbar
1. Click on the Download button below to download the Remove Explorer Bar.zip file.
2. Disable Aero.
3. Download and install "Add_Take_Ownership.reg".
- Right click on the Desktop, select "Personalize"
- Select "Windows Classic" theme:
4. Determine whether your operating system is 64 bit or 32 bit.
- Extract: "Add_Take_Ownership.reg"
- Run: "Add_Take_Ownership.reg"
- If prompted by User Access Control, then select "Yes".
- "Registry Editor" will ask something like:
- Select "Yes"
- "Registry Editor" will say something like:
- Select "OK"
5. Taking control of necessary files.
- Right Click on "Computer", select "Properties"
- Look next to "System type:", it will say one of these: "64-bit Operating System" or "32-bit Operating System":
WarningYou MUST back up the following files if you ever wish to revert back. One way you might backup a file is by copying the original file and then renaming the copy "shellstyle - Original.dll" or "shellstyle - Backup.dll". Make sure you do a backup file for each file that you are going to change.
- Navigate to the folder:
Code:C:\Windows\Resources\Themes\Aero\Shell\NormalColor- Right click on the file: "shellstyle.dll", select "Take Ownership":
- The following Steps 5-7 are for "64-bit Operating System" only.
- Navigate to the folder: "C:\Windows\SysWOW64"
6. If your system is a "64-bit Operating System" perform steps 1-2.7. If your system is a "32-bit Operating System" perform steps 1-2.
- Extract (drag and drop to your desktop) and run the following files: "Shellstyle Extract x64.exe", "Shellstyle Extract x64_2.exe" from the download in step 1 above.
8. Re enable your original theme.
- Extract (drag and drop to your desktop) and run the following file: "Shellstyle Extract x86.exe" from the download in step 1 above.
9. You are Done!
- Right click on your Desktop, click "Personalize"
- Enable your desired theme
OPTION TWOTo Restore Windows Explorer Toolbar
1. Disable Aero.
2. Restore Backups.
- Right click on your desktop, click "Personalize"
Code:C:\Windows\Resources\Themes\Aero\Shell\NormalColor- Change the file "shellstyle.dll" to another name I.E. "shellstyle - NEW.dll"
- Put the original file back in this folder and name it "shellstyle.dll"
3. Re enable your original theme.
- Navigate to the folder: "C:\Windows\SysWOW64" (Note this folder is only on 64 bit versions of windows 7)
4. You are Done!
