Windows 7: Empty Recycle Bin - Add to Desktop Context Menu
07 Apr 2019   #20
Brink
64-bit Windows 10 Pro
Hello @igeorge George,
You might see if you may be able to add "Empty Recycle Bin" back to the context menu of the Recycle Bin using the tutorial below.
Remove Empty Recycle Bin from Context Menu of Recycle Bin in Windows | Tutorials
Next, you might see if the tutorial below may be able to fix the Recycle Bin icon not refreshing.
Recycle Bin | Vista Forums
07 Apr 2019   #21
igeorge
xp , vista
I will try
THank you Brink
I will try.
07 Apr 2019   #22
igeorge
xp , vista
icon ok
Hello Brink
The icon is fixed now.
Thank you very much.
I go to step two.
07 Apr 2019   #23
igeorge
xp , vista
Missing part of registry
Hello Brink,
I do not have the subfolders like you have.
The key has just DefaultIcon, but no subfolders.
See the screenshot
07 Apr 2019   #24
igeorge
xp , vista
it works now.
After i changed the permission to the whole key
HKEY_CLASSES_ROOT\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}
I run the script, and now i have the empty recycle bin option.
I still do not know what i have missing the subfolders for this key, but the original problem is fixed.
The icon change , the empty option is now back.
Thank you
P.S.
Do you know by any chance how to make windows 7/64 ultimate service pack 1 the font darkers.
As you can see on my screenshot they are horrible.
I use the windows classic display and no aero.
But when i open a folder, i barely can read.
Selecting a high contrast theme, it interfere with some of my programs (like PCB design )
07 Apr 2019   #25
Brink
You're most welcome George. I'm glad the original problem is now sorted.
You could test using different fonts or a bolded font using an option in the tutorial below to see if you may find one that looks better to you. I would recommend to create a restore point before doing this. This way you can do a system restore and select a restore point before this to quickly undo it if needed.
Fonts - Change
How do I delete unwanted context menu items in the Recycle Bin
Hi all...I am a brand new member and I have tried to look up all of the other threads on this site regarding how to delete unwanted context items that show up when right clicking the Recycle bin. I don't know how these items got there but I am nearly always clicking on them instead of emptying the...
Customization
Getting back 'Empty Recycle Bin' Context Menu On Recycle Bin
Hey! I accidentally removed my Empty Recycle Bin option from Recycle Bin context menu while playing around with context menu editing tool (Windows 7 Manager). I cannot to system restore because I installed many things, etc. which would be hassle to sort out. Could you please provide me with a...
Customization
Recycle Bin - Add or Remove from Desktop Context Menu
How to Add or Remove "Recycle Bin" from Desktop Context Menu The Recycle Bin provides a safety net when deleting files or folders. When you delete any of these items from your hard disk, Windows places it in the Recycle Bin and the Recycle Bin icon changes from empty to full. This will...
Tutorials
Context Menu - Add Empty Folder and Subfolders
How to Add "Empty Folder and Subfolders" to Context Menu in Windows This tutorial will show you how to add Empty Folder and Subfolders to the context menu to be able to automatically permanently delete all file contents of a folder and it's subfolders without deleting the subfolders in...
Tutorials
Recycle bin (again) - need default context menu
After some unconsious playing around - I managed to loose most of the context menu for my Recycle bin. "empty recycle" is gone, "delete" is gone etc... I tried to create a new user account and copy the settings from there - but - same things ... So - please - if anyone could dump their...
General Discussion
Twitter Facebook
