How to Turn Presentation Settings On or Off in Windows 7 and Windows 8
InformationPresentation settings are options on a laptop or desktop that you can apply when giving a presentation. When presentation settings are turned on, your laptop stays awake and system notifications are turned off. You can also turn off the screen saver, adjust the speaker volume, and change your desktop background image when presentation settings are turned on.
This tutorial will show you how to either turn on, change, or turn off presentation settings in Windows 7 and Windows 8.
NoteIn Windows 7, "Presentation Settings" is only available in the Windows 7 Professional, Windows 7 Ultimate, and Windows 7 Enterprise editions.
In Windows 8, "Presentation Settings" is only available in the Windows RT, Windows 8 Pro, and Windows 8 Enterprise editions.
OPTION ONETurn Presentation Settings On or Off using Windows Mobility Center
1. Open Windows Mobility Center.
2. To Turn On Presentation Settings
A) In the Presentation Settings tile, click/tap on the Turn on button, and go to step 4 below. (See screenshot below)3. To Turn Off Presentation Settings
NOTE: This will turn on the presentation settings that you have set in step 4.
A) In the Presentation Settings tile, click/tap on the Turn off button, and go to step 5 below. (See screenshot below)4. To Change the Presentation Settings
5. When finished, you can close Windows Mobility Center if you like.
OPTION TWOTurn Presentation Settings On or Off in Presentation Settings
1. Press the Windows + R keys to open the Run dialog, type presentationsettings.exe, and press Enter. (See screenshot below)
NOTE: If you would like to create a Windows Mobility Center shortcut, then right click on presentationsettings.exe at the top of the Start Menu below and click on Send to and Desktop (create shortcut). You can also create one from the exe file located at2. To Turn On Presentation Settings
C:\Windows\System32\PresentationSettings.exe.
A) Check the I am currently giving a presentation box, and go to step 4 below. (See screenshot below step 5)3. To Turn Off Presentation Settings
A) Uncheck the I am currently giving a presentation box, and go to step 5 below. (See screenshot below step 5)4. To Change the Presentation Settings
A) Change the settings for what you want when giving a presentation, and go to step 5 below. (See screenshot below step 5)5. When finished, click/tap on OK. (See screenshot below)
OPTION THREETurn Presentation Settings On or Off using a Command
1. Open the Run (Win+R) dialog, or a command prompt.
A) Type the command below, and press Enter.3. To Turn Off Presentation Settings
PresentationSettings.exe /start
PresentationSettings.exe /stop
Related Tutorials
- How to Open and Use Mobility Center in Windows 7 and Windows 8
- How to Create a "Windows Mobility Center" Shortcut in Windows 7 and Windows 8
- How to Enable Windows Mobility Center on a Desktop Computer in Windows 7 and Windows 8
- How to Change the Main Display in Windows 7
- How to Enable or Disable Windows Mobility Center in Windows 7 and Windows 8
- How to Enable or Disable Presentation Settings in Windows 7 and Windows 8
- How to Create a "Presentation Settings" Shortcut in Windows 7 and Windows 8
- How to Change the Windows 7 Display Presentation Mode
