Drive Icon - Change
Page 7 of 12 FirstFirst ... 56789 ... LastLast
  1. Posts : 42
    Change Icon for Droid?
    I tried this same strategy for my Motorola Droid 2, it didn't really work, is there a way that I could possibly do this for my droid? or just change the icon in general, i only want it for my computer so it doesnt need to be on the droid but that would be cool too :)
  2. Posts : 72,050
       #61
    Hello mhelseth,
    I'm not sure this would work with a Droid 2 smartphone.
  3. Posts : 42
    yeah i was trying to figure out why and it turns out that every time my phone is unplugged, it deletes the autorun file because its a security threat
    So I guess I will have to do without :/
  4. Posts : 72,050
       #63
    mhelseth,
    Does any of the other options work to change the icon if you use the drive letter that is assigned to the smartphone?
  5. Posts : 42
    what did you mean by other options? I did assign it a drive letter (Z:) and when i try to change the icon through properties it doesnt even say there is an original Icon, it is strange. so when I click to change it, nothing happens. Or did you mean the other options on this thread? I havent tried any of those but I will now!
  6. Posts : 42
    Awesome! I just tried the second option and it worked flawlessly, thanks brink for these amazing tutorials!
  7. Posts : 72,050
       #66
    Yep, I meant another option in the tutorial. I'm happy to hear that it worked for you. :)
  8. Posts : 82
    Microsoft Windows 7 Home Premium, Service Pack 1 64-bit
       #67
    @ Shawn
    Brink said:
    Jenn,
    You might see if clearing both the thumbnail cache and icon cache may help first. If not, then delete the autorun.inf file, restart, and try again to see if they still show or not to start over.
    Hi Shawn,
    Well I don't know which of the above suggestions
    helped but bottom line I
    am finally HEART free.
    I had no problem with clearing the Thumbnail Cache
    but a totally different story with
    Icon Cache.
    I downloaded the bat file but every time I tried
    to run it I got
    an error message
    (btw, I did go to properties and unblocked it) ...
    I'd get the following error message about not
    being able to locate the path specified.
    I'd click Y to restart then get the message
    "Restart Aborted"
    I finally decided to skip this step and delete both the
    heart icon and the autorun.ini file.
    I then re-started the computer and the generic icon
    was back on the G: drive
    but all my assigned folder icons
    were now missing and the dreaded RED HEART
    was still present in ALL the sub-folders ...
    I'm like Omigosh NO ~!!
    I started all the way back over ...
    Cleared the Thumbnail Cache,
    used YOUR manual instructions for clearing Icon Cache.
    The computer rebooted
    I did the Safely Remove G: drive waited a minute
    and then re-plugged the drive back in.
    Finally all the RED HEART icons were gone.
    Now I need to assign an icon to the G: drive ..
    I'm almost afraid to try it again )
    but I really need a Drive Icon I can spot fast.
    Is there a way you know of to reassign all those
    missing folder icons without having to physically
    browse to the stored icon again ??
    I can open each .ini file and see what icon
    was used
    and the path of where the icon is ....
    but it'll take a long time to do all of those.
    Thank YOU for all your help.
    Jenn
  9. Posts : 72,050
       #68
    Jenn,
    I'm happy to hear that your folders are now heartless, but I'm sure that you're not. :)
    The error message you see from running the BAT file to clear the icon cache just means that the IconCache.db file had already been deleted. That's all. After restarting the computer the IconCache.db file will automatically be recreated fresh and reset.
    You could try using OPTION TWO or OPTION THREE in this tutorial to change the drive icon of the G: drive to see if that would work better than using the autorun.inf file.
    I'm not sure what you mean by missing folder icons. What icons are missing on them? Could you post a screenshot of what they look like now?
  10. Posts : 82
       #69
    Brink said:
    Jenn,
    Hi Shawn,
    Thanks for the laugh, and although I am now
    THANKFULLY "Heartless"
    on the drive,
    personally I still have my sweet heart ..
    What I lost in getting rid of the Hearts, was FOLDERS ONLY icon/picture
    that I had assigned a dedicated one to so I could locate that folder faster ..
    Now it's showing a picture of a regular folder.
    BEFORE: (Kind of, I adjusted one of the earlier screenshots)
    CURRENTLY:
    ( I had already assigned a new icon/picture to the D: drive Backup Folder)
    I guess the only way to get those back on to the folders is to manually
    browse back to the icon I previously used and re-assign it.
    I'm not complaining I really wanted to LOOSE that Heart thing.
    I was just curious if there was a trick to get those back without
    all the time consuming stuff.
    Btw, I got so distracted looking at all the Hearts ..
    I'm no longer a HEART person ..
    I'm now a Butterfly Gal ... the old G: drive is currently a Butterfly.
    I want to Thank YOU for all the help and the neat tutorials ...
    Especially the time you must have devoted to writing them.
    Jenn
