Drive Icon - Change
Page 8 of 12 FirstFirst ... 678910 ... LastLast
  1. Posts : 72,051
       #70
    You're most welcome Jenn. :)
    Yeah, unfortunately you would need to manually customize each folder icon that you do not want the default icon/thumbnail preview for.
  2. Posts : 69
    Windows 7 Home Premium 32bit
       #71
    thanks brink
  3. Posts : 72,051
       #72
    You're welcome Thomas. :)
  4. Posts : 1
    Windows 7 Ultimate 32 Bit
       #73
    thank you so much, this tutorial help me to recover my drive icon
    i previously install Harddisk Sentinels and it changed my drive icon to HD sentinel icon, when i uninstalled it my drive icon went blank, i was desperate
    thanks so much, you guys rawkkkk!! ^^
  5. Posts : 72,051
       #74
    You're most welcome Boulve, and welcome to Seven Forums. :)
  6. Posts : 2
    Windows 7 Professional x64
       #75
    Thanks for the great tutorial, Brink. I think I am having some issues with my ico file. I downloaded the Porsche.ico file from earlier in this thread and got it to work successfully using the Registry option. However, when I use my ico it doesn't seem to work. I created the file as a png with Fireworks and used png2ico to convert it. It's a 128 x 128 (the same dimensions as the Porsche file).
    Here is the file:
    Boxcryptor.zip
    Any thoughts?
    Thanks in advance!
  7. Posts : 72,051
       #76
    Hello Mitch, and welcome to Seven Forums.
    The icon is working fine for me, so there must have been a mistake made somewhere along the way. Double check to make sure that you have the icon unblocked and in a location that any user account set to use it has access rights to it.
    Which option did you use?
  8. Posts : 2
       #77
    I re-created the ico, this time by using iconviewer to extract the ico from a .exe file that uses the same icon. Tried it again and it worked this time. Not sure why I was having trouble with the first file. Maybe a cache issue or something.
    Thanks for double-checking! I was using the registry option.
    Cheers and keep up the great work!
    Mitch
  9. Posts : 72,051
       #78
    You're welcome Mitch. I'm happy to hear that you got it working. :)
  10. Posts : 21
    Windows 7 Enterprise SP1 x64
       #79
    My autorun.inf files stopped working... any idea why?
