#80
@BRINK
Nice Tutorial!! I tried this it worked, bt i hav little problem. The problem is when i change the view of Drive icons to "Large" or "Extra Large". My new icon is working properly.... bt when i change the view to "small"/"medium"/"tile"/"content"/"Details"/"List" it shows the old icon again. i'm confused.. hw's this happening.????
Also, i wanna know how to change icon of more than one drives ..as this trcick is for only 1 drive.
Suggestions Appreciated
Hello Shanucyborg, and welcome to Seven Forums. :)
What icon or .ico file did you use for the drive?
If .ico file, is it a 256x256 Vista styled icon?
Yes, i used a 256x256 .ico file.
There's nothing wrong with the icon. Give OPTION THREE for all users a try with it instead to see how it works then. That option tends to work best. :)
Ok..
Hello,
I did everything in option two and it worked fine, but when I turned on my PC the next day, all icons were changed back to default.
In Registry Editor, everything in "HKEY_CURRENT_USER\Software\Classes\Applications\Explorer.exe" was deleted, so I repeated option two again and successfully changed my icons, but after restart they were again changed to default and there was nothing in "Explorer.exe".
I tried to do it in Safe Mode and also I set permission on Explorer.exe to "read only", but neither of them worked.
I don't know what am I doing wrong and why the Registry Editor won't keep my changes after restart...
Could someone help me?
