Drive - Rename
  1. Posts : 521
    Windows 7 Ultimate x64 Service Pack 1
    Brink said:
    Hello oreo27,
    I've had a few LiteOn drives, and I never had an issue with them. :)
    Hi Shawn,
    Sounds good. Hope this one lasts me the same number of years my ASUS did :) Cheers!
  2. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    Shawn, I used Option Three to rename my two optical drive but the previous name remains. Is this normal? the bits I added are underlined. My registry already had the key DriveIcons which was empty.
    oreo27 said:
    Neat trick. Helped me out when trying to distinguish my new LiteOn iHAS124 drive. My old Asus drive is starting to fail so I got it. Anyone know if LiteOn is any good? :)
    I had two of the same drive, one was a bit noisy but both worked as they should.
  3. Posts : 521
       #12
    Yup, they should show exactly that as these are just labels. Sounds great. Two positive reviews for a drive that I just picked up without even checking. Lol
  4. Posts : 72,051
    Hello Gary,
    Yeah, devices with removable storage, such as a DVD drive, can only be renamed by adding a label at the end of the drive description. The drive description will always be there for these type.
  5. Posts : 24,479
       #14
    Thanks for the info oreo27 and Shawn. :)
  6. Posts : 521
       #15
    No worries. Glad I could be of help :)
  7. Posts : 72,051
       #16
    You're most welcome Gary. Glad we could help. :)
  8. Posts : 24,479
       #17
    Me too, since I decided to hang around a few days after your first help you gave me.
  9. Posts : 759
       #18
    hI,
    I tried your autorun.inf file method, but it does not capture the label . I tried also a icon of 34 pixels. The commands were only three . First line autorun with [], followed by label i choose, in the second line, and icon=choosen icon. I copied the same ico in the same place, that is usb drive and in that, when i plug out and replug, nothing happens. No change in the lable or icon.Where am i missing? Brink
  10. Posts : 72,051
       #19
    Hello jraju, :)
    Please go ahead an post the text in your autorun.ini file in a code box #.
    Was your autorun.ini file and .ico file saved to the root directory of the USB, and not in a folder?
