System Recovery Options
Page 7 of 12 FirstFirst ... 56789 ... LastLast
  1. Posts : 72,051
       #60
    I'm happy to hear that you got it working great again. :)
  2. Posts : 3
    Windows 7 Ultimate 32bit
       #61
    Hi! In my problem, after step 2 in option 2, it doesn't go to the system repair after windows is loading files but instead it goes like this It just loads and loads for a long time.. What should I do?
  3. Posts : 72,051
       #62
    Hello giancarlo, and welcome to Seven Forums.
    That screen would be normal after step 2. From that loading screen you would normally see the screenshot under step 3 or 4 afterwards. Do you see them afterwards? If so, how actual long is the long time until you do? :)
  4. Posts : 3
       #63
    It just loads for hours, does it really work that way?
  5. Posts : 72,051
       #64
    Does it ever finish loading?
    If it's an old system with low specs, then it may take a while. Normally, it's only a few minutes at most though.
    What are the system specs for that computer?
    What are you using to try and boot to the System Recovery Options screen with?
  6. Posts : 3
       #65
    Windows 7 Ultimate 32 bit. I'm using Toshiba Satellite L310. I was gonna use it to repair my computer because of a boot failure..
  7. Posts : 72,051
       #66
    Looking at the default specs for that laptop, things may run slower than usual on it since it only has 1GB RAM and is a older model.
    You might try the DOS HDD diagnostics program at the Toshiba link below to see if there may be an issue with the HDD.
    Software Utilities
  8. Posts : 2
    Windows 7 64 bit
       #67
    log in problems
    hi i used option 2 and when i reached step 5 and clicked next it gave me an error telling me that "you to be logged in to access system recovery options" and then my computer restarts
  9. Posts : 72,051
       #68
    Hello Jazz, and welcome to Seven Forums.
    What are you using to boot from to boot to the "System Recovery Options" screen?
  10. Posts : 2
    Windows 7 64 bit
       #69
    im using a windows 7 64 bit boot disk made off another computer
