Recycle Bin - Pin to Taskbar
Page 5 of 8 FirstFirst ... 34567 ... LastLast
  1. Posts : 133
    windows 7 home premium sp1 x86
       #40
    using the small icon works, its not as nice as the big one but it does the trick
  2. Posts : 72,051
       #41
    Gohardsupreme,
    I'm happy that will do the trick for you. Sorry that there doesn't seem to be another workaround for it.
  3. Posts : 133
       #42
    thanks for the help its not a big deal. i can deal with it
  4. Posts : 308
    Windows 7 Professional (x64)
       #43
    Thanks for the tip! I tried adding rep, but it won't let me for some reason...
  5. Posts : 18
    7 Home Premium x64
       #44
    Solid! Now my desktop is totally cleared!
  6. Posts : 2
    Windows 7 Ultimate x32
       #45
    Really useful thanks :)
  7. Posts : 34
    Windows 7 Ultimate 64 bit & Ubuntu 10.04
       #46
    All I did was pin it inside my Windows Explorer and it works fine for me.
    But thanks for the tutorial, seems like I will have to try it out sometime.
  8. Posts : 4
    Thanks!
  9. Posts : 2
    Windows Seven Ultimate
       #48
    hey i have a problem, i pinned the recycle bin already it now it wont delete from my desktop
  10. Posts : 1,797
    Windows 7 Ulti. x64
       #49
    Aarkan Welcome to SevenForums
    Did you follow the link provided in step number 15 of the tutorial? You must unselect recycle bin from default desktop icons. Good luck to you.
