How to Pin the Recycle Bin to the Windows 7 Taskbar
InformationThe Recycle Bin provides a safety net when deleting files or folders. When you delete any of these items from your hard disk, Windows places it in the Recycle Bin and the Recycle Bin icon changes from empty to full.
This will show you how to create a Recycle Bin shortcut with Empty Recycle Bin in the context menu, and how to pin this shortcut to the taskbar as a toolbar.
NoteRemovable drives do not use or have a Recycyle Bin. Files deleted from removable drives are permanently deleted instead.
EXAMPLE: Recycle Bin Unpinned and Pinned from the Taskbar
Here's How:
1. Make sure the Recycle Bin is on the desktop.Enjoy,
2. Right click on the desktop and select New and Folder , then rename it anything you like. (i.e. Trash Bin)
3. Drag & drop the Recycle Bin on the new Folder to create a shortcut.
NOTE: You could also Pin to Start Menu this new Recycle Bin shortcut by pressing and holding Shift, then right click on the shortcut, and click on Pin to Start Menu.
4. Save the new Folder (containing Recycle Bin shortcut) to the directory of your choice (i.e. C:\Trash Bin) by dragging and dropping.
5. UnLock the taskbar.
6. Right-click on the taskbar and select Toolbar and New toolbar...
7. Navigate to the location you saved the New Folder (Ex: Trash Bin), select it and click on the Select Folder button.
8. This places the new Toolbar and a Separator (dotted lines) on the taskbar.
9. Right click on the Separator and uncheck Show Text and Show Title.
10. Right click on the Separator and select View and Large Icons.
11. You now have the Recycle Bin pinned to the taskbar.
12. To Keep the Recycle Bin on Right Side of Taskbar
A) Left click on the Separator to the left of the folder and hold, then drag it to the left and right to make any adjustments to how you want the Recycle Bin positioned on the right side of the taskbar. (See screenshot above)13. To Have the Recycle Bin on Left Side of Taskbar
B) Release the left click when done.
C) Go to step 14.
A) Left click on the Separator of the pinned taskbar programs on the far left side and hold, then drag it to the right past the Recycle Bin and release. (See screenshot below)14. Lock the taskbar.
B) Left click on the Separator of the pinned taskbar programs on the now right side and hold, then drag it to the left next to the Recycle Bin and release. (See screenshot below)
15. Remove the Recycle Bin from the desktop.
NoteYou do know that when you drag & drop copied shortcuts from the Start Menu in with the Recycle Bin shortcut, that those automatically become Quick Launch items beside the Recycle Bin. By doing it that way you can "kill two birds with one stone".(See screenshot below)
Related Tutorials
- How to Backup and Restore Taskbar Toolbars in Vista and Windows 7
- How to Pin or Unpin a Program to the Windows 7 Taskbar
- How to Enable or Disable Windows 7 Taskbar Pinned Programs
- How to Allow or Prevent the Windows 7 Recycle Bin Icon to Display
- How to Add or Remove a Default Desktop Icon in Windows 7
- How to Pin Your User Files Folder to the Windows 7 Taskbar
- How to Pin the Control Panel to the Windows 7 Taskbar
- How to Change the Windows 7 Pinned Windows Explorer Taskbar Icon Open To Target
- How to Pin Computer to the Windows 7 Taskbar
- How to Pin or Unpin a Folder to the Windows 7 Taskbar
- How to Show or Not Show All Folders in the Windows 7 Navigation Pane
- How to Add Empty Recycle Bin to the Windows 7 Desktop Context Menu
- How to Rename the "Recycle Bin" in Windows 7
- How to Add or Remove "Recycle Bin" from Desktop Context Menu
- How to Change the Recycle Bin Storage Size in Vista and Windows 7
- How to Add or Remove the "Recycle Bin" from the Windows 7 Navigation Pane
- How to Add or Remove Recycle Bin from Favorites in Navigation Pane in Windows
- How to Fix Corrupted Recycle Bin in Windows
