#30
Brilliant tutotrial thank you
Hi, I followed the instructions wrt Instant restore point. But when I click on the desktop shortcut it opens in a notepad.
Pl. halp/advice me how to correct the anamoly.
Also, i am a novice and have just started using Win 7 Ultimate 64 bit OS. My sytem is an Dell laptop 6420. Thank.
Hello Futuristic, and welcome to Seven Forums.
It sounds like your VBS file extension association may be messed up. Download and merge the VBS option in the tutorial below to see if the Instant restore point works afterwards. :)
I can now create automatic system restore. But I have an irritating problem.
Whenever I shutdown and reboot my laptop, Everytime, I need to remerge the default VBS file. Is there a way I can solve the problem permanently?
I also noticed that when I go "Open with"and go to "other programs" the option stating "always use this program to open this kind of file is greyed out"and I cannot check thsi option.
I use win 7 64 bit OS.
Thanks for all the help.
Hello Futuristic,
Unless you really have a need to create a restore point at every startup, I wouldn't recommend doing this since it will use up all of your max restore space faster and delete older restore points faster.
Did you unblock the VBS file?
What are you using "Open with" on, and where are you using it at (ex: in Default Programs or right clicking on file)?
