System Restore Point : Create at System Startup
Page 7 of 16 FirstFirst ... 56789 ... LastLast
  1. Posts : 2
    Zuid-Holland
       #60
    A few years later, but I hope you can help me.
    When I click on the file in Explorer I get a system resore point. But when I make a task in Windows 8.1, Windows ask me what program I like to use for opening the vbs-file. I don't know what to answer.
  2. Posts : 11
    Win 8.1 Professional 64 bit, Win 7 Ultimate 64 biut
       #61
    Peter, you want to chose "Windows Script Host", WSH, or maybe it will be termed "Windows-Based Script Host" (Wscript.exe) However, the task manager should not be asking you that, it is baked into the OS. On my Win 8.1 task manager, I do not get that question.
    Some possible related links:
    Fix: Windows Script Host access is disabled on this machine
    Overview of Windows Script Host in Windows
  3. Posts : 2
    Zuid-Holland
       #62
    When I choose for wcript.exe I don't get the question anymore, bit I don't see a new system restore point.
  4. Posts : 25
    8.1 Pro x64
       #63
    The script for task scheduler does not work in Windows 8. Based on System Restore Point Shortcut you need to take account of the SystemRestorePointCreationFrequency registry setting. Updated vbs is enclosed.
  5. Posts : 11
       #64
    Thank you adamf
    Adamf,
    Thanks. I will try your new script
  6. Posts : 54
    How to have a restore point created:
    a. automatically
    b. ONCE a day, at pc start (i.e. not at each restart)
    c. automatic naming e.g. RP-ddmmyyyy-hhmmss
    Thanks!
  7. Posts : 294
    Windows 7 Pro SP1 x64
       #66
    Thanks, BFK... excellent presentation. Extremely easy to comprehend without raising any internal 'what to do' questions.
  8. Posts : 2
    Windows 10 pro 64 bit
       #67
    Does not work in windows 10 with the task scheduler but the all the shortcuts work
    can I get the restore to work when shutting down?? I have lost the start button 5 or 6 times the last time had to use restore to get it back
  9. Posts : 72,054
       #68
    Hello Mike, and welcome to Seven Forums. :)
    Please post back with screenshots showing your settings from METHOD TWO to see if anything may stand out.
  10. Posts : 2
       #69
    System Restore Point : Create at System Startup-restore-1.jpg
    System Restore Point : Create at System Startup-restore-2.jpg
    System Restore Point : Create at System Startup-restore-3.jpg
    System Restore Point : Create at System Startup-restore-4.jpg
    System Restore Point : Create at System Startup-restore-5.jpg
    System Restore Point : Create at System Startup-restore-6.jpg
