#70
It looks like the problem may be that you have it set to run at startup instead of on a schedule.
By default, Windows will not run anything elevated at startup for security purposes.
If you like, see if using the tutorial below to create an elevated shortcut to run the .vbs file from your Startup folder may work instead.
