System Restore Point : Create at System Startup
Page 14 of 16 FirstFirst ... 41213141516 LastLast
  1. Posts : 25,847
       #130
    Just a thought.
    I believe it would be a fine time to reboot and then see if things work as you desire.
    I would wait and see if Brink agrees with me. He is the expert.
  2. Posts : 72,037
       #131
    It can't hurt to try, but I don't think it'll make any difference.
  3. Posts : 24
       #132
    For some odd reason Zemana thinks that the tasks that I created with the script are Win32Poweliks trojans. Nothing else labels them as trojans. Is that normal?
    Other than that though it seems to be working for now.
  4. Posts : 72,037
       #133
    I'm not sure why it would think the tasks are Trojans.
  5. Posts : 24
       #134
    Well it did. And for some reason the task still works even though Zemana claims it deleted the "trojan".
  6. Posts : 72,037
       #135
    Gotta love those false positives.
  7. Posts : 24
       #136
    Yea, but what concerns me is how the task scheduler still runs those tasks without them being located in the task folder. Zemana deleted them but I can still run the tasks.
    How is that even possible?
  8. Posts : 72,037
       #137
    I don't know. The task would need to be there for it to still run. Odd.
  9. Posts : 24
       #138
    Should I delete the current tasks and create a new one just to be safe?
  10. Posts : 72,037
       #139
    Since they're working, I'd let them be if you like.
