System Image Recovery
Page 28 of 42 FirstFirst ... 18262728293038 ... LastLast
  1. Posts : 2
    Windows 7 Home Premium 32Bit
       #270
    System Image not found
    I just restored my computer to factory settings and was looking to use a System Image I had made before to recover the data on my drive.
    However, the System Restore program on my computer could not find any System image backups when I tried to work it.
    I have 2 images currently saved. One in drive C: and another in and external HDD (E:). Neither one is being picked up.
    Any ideas?
  2. Posts : 72,052
       #271
    Hello Nasha,
    A system image is not a data backup, but a complete drive clone instead. It will wipe your drive and restore Windows 7 back to how it was when the image was created.
    However, you could use the tutorial below to extract files from the system image if it's still on your E drive.
    System Image - Extract Files Using Disk Management
  3. Posts : 686
    Windows 7 x64 Ultimate SP1
       #272
    Well, what can I say? It took a wee bit longer to get the replacement computer, but as for the restoration process & result - complete satisfaction.
  4. Posts : 72,052
       #273
    Hello Tomislav,
    That's great news. :)
  5. Posts : 47
    win 7 HP 64bit
       #274
    Hi Brink,
    I sent you a PM as i wasnt sure how often you check here as this thread hasnt been used for a while.
    Ive been reading through your Windows Back up and Restore threads which are fantastic by the way.
    Was wondering how i go about this:
    My current C Drive is a 500GB WD HDD
    I have made an image of this on my 1TB Samsung HDD F drive
    I want to take replace the existing C drive with a Samsung 500GB HDD due to issues ive had with the WD drive.
    The new 500GB Samsung is currently my G drive.
    I want to restore the system image from the 1TB F drive to the 500GB G drive and then make this the new C drive.
    The existing C drive will be used as an external drive only.
    Can you tell me how i restore to the G Drive as it seems if i follow the steps it will restore image back to the current C drive unless i missed something?
  6. Posts : 72,052
       #275
    Hello Rod,
    Yes, if you created a system image of your old WD C: drive to your F drive, you should be able to do a system image recovery with the image on the F drive to your new Samsung drive using the steps in the tutorial.
    I would recommend to remove your WD drive, connect the G drive, and do the system image recovery this way though. This way if something should go worng, you could just pop the old C drive back in, remove the G drive (now new C drive), and be back to where you were on the next restart.
  7. Posts : 47
    win 7 HP 64bit
       #276
    Hi Shawn,
    Firstly thanks for your prompt reply.
    What i'm confused about is, if i take out the current c drive and replace it with the current G drive i wont be able to boot to windows right? So would i have to use
    option 2. If you are "Not Able to Boot" into Windows 7 - from the tutorial?
  8. Posts : 72,052
       #277
    You would use step 3 in STEP TWO. :)
    STEP ONE is only if you had renamed or moved the WindowsImageBackup folder.
  9. Posts : 47
    win 7 HP 64bit
       #278
    I have a Win7 Disc but its an OEM Version - i dont think this has a repair section in its menu does it. I think i looked at that once before and the only option (from memory) was installation. I will look at it again though.
  10. Posts : 72,052
       #279
    Is a retail OEM copy that you purchased, or is it a factory recovery type OEM disc that came with the computer?
