System Image Recovery
Page 29 of 42 FirstFirst ... 19272829303139 ... LastLast
  1. Posts : 47
    win 7 HP 64bit
       #280
    Hi B,
    Sorry had to go and pick the kids up from school and just got back
    Its an OEM retail copy that i bought when i built my machine last year.
    I found the repair section but it shows a windows image in D location. My D is an optical drive which has the windows 7 disc in it. It also says the image date is yesterday - the 1st of September - but i backed up today which is the 2nd of Sept(Australian Time). Does it show the U.S. time rather than my current Australian time?
  2. Posts : 72,051
       #281
    Do you have the G HDD connected to the computer with your system image backup on it?
    Are you able to select your G HDD and the image you have on it at step 6 if it's not displaying at step 5?
    What type of HDD is your G drive? For example: external (USB) or internal
  3. Posts : 47
    win 7 HP 64bit
       #282
    at the moment i have the new empty C drive and F drive which has the image on it.
    When i boot from windows CD it doesnt show F drive - it shows D as location.
    both drives are internal drives
  4. mjf
    Windows 7x64 Home Premium SP1
       #283
    Brink said:
    You would use step 3 in STEP TWO. :)
    STEP ONE is only if you had renamed or moved the WindowsImageBackup folder.
    This is referring to booting from a Windows made system repair disk which you make
    System Repair Disc - Create
  5. Posts : 47
    win 7 HP 64bit
       #284
    when i boot from CD and get to "Re-image your computer" under Location it says New Volume (D) Most Recent system image 9/1/2011 6:31:54PM and states my computer name.
    As my time zone is GMT +10:00 and it is showing current time zone GMT -8:00 i assume this is the correct one as the time i saved would be about right if i add 18 hours to it.
    I still dont know why its showing Location as New Volume (D: )
    Hey mjf
    so are you saying i'm using the wrong method?
    In the "Re Image your Computer" window and click on Advanced and then Install a driver i click on the "Look in" Drop down box it shows all the drives available etc. it shows C drive , New Volume D drive and E & F as CD drives. These are not the normal drive letters. It seems they have been rearranged somehow. The thing is , it it showing D as a HDD but if i select that image location it says "The System image restore failed. No Disk that can be used for recovering the system disk can be found."
    What the??
  6. mjf
       #285
    Roo Boy,
    Assuming you are following the Brink advice then you are spot on track.
    Hang on......
    You can boot ok from the DVD but it's a drive letter issue isn't it??
    When you boot from a DVD all your drive letters don't often match the letters when you boot from Windows. So forget about the drive letters just look for the image and the disk name.
    And image times will be screwy as well doing this from Australia say.
  7. Posts : 72,051
       #286
  8. Posts : 47
    win 7 HP 64bit
       #287
    Hi mjf,
    I'm trying to use the OEM Win7HP Disc.
    I can boot from this CD and then get to the repair section.
    It can find the image i created but when i click on it it says that "The System image restore failed. No Disk that can be used for recovering the system disk can be found."
    When i put the original C drive back in and click on my computer the New Volume is showing as F drive but shows as D when new HDD is attached. Also the optical drives now shows as D & E but with new HDD they show as E & F.
    Im stumped
    edit: ok i see you comment on the drive letters but why wont it find the image i created when i try and run it - it shows as being there but then fails if i try and use it
  9. Posts : 72,051
       #288
    You could Create a System Repair Disc to boot from and use instead to do the system image recovery as outlined in the tutorial.
  10. Posts : 47
    win 7 HP 64bit
       #289
    ok brink, will give that a bash after dinner.
    thanks
