#330
Bilvihur,
If you are wanting to have the same OS on more than one drive, then you would also need to have a separate product key number for each one to activate with as well. Otherwise it would violate the EULA.
That's not going to be a real easy task using System Image Recovery since you would basically have to disconnect HDD 0, restore to HDD 3 which would be formatted first, when finished connect HDD 0 back, then use something like the free program "EasyBCD" to fix the MBR to be able to have both OS's listed at boot to select which on you wanted to boot to. If you don't fix the MBR, then you would have to use the Boot Menu at startup to select to startup to the other HDD instead of the default one.
