#350
Just to make sure you know, that if you just copied and pasted the WindowsImageBackup folder to the root of the external drive, it may not work to do a system image recovery with. It really needs to be saved to the external HDD when it's created instead.
By default, a system image recovery will format everything on each hard drive that was included in a system image, and will only restore what is included in the system image back. Since the external HDD is not included in the system image since that's where you saved it to, it will not be formatted. :)
