Windows 7: System Image Recovery
How to Do a System Image Recovery in Windows 7
Published by Brink
23 Nov 2008
information   Information
This will show you how to restore your Windows 7 hard disk back to exactly how it was when you created a system image backup.
warning   Warning
  • You can only do a system image recovery to a HDD that is the same size or larger than the one the system image was created from. You will not be able to do a system image recovery to a smaller HDD.
  • When you restore your computer from a image backup, it is a complete restoration. You can't choose individual items to restore, and all of your current programs, system settings, and files are replaced.
  • If your backup image is on a external device (ex: USB drive), then make sure it is connected before starting. If USB drive, then also make sure that you have your BIOS settings (ex: Legacy USB) set to allow USB devices at boot.
  • A system image recovery will format everything on each hard drive that was included in a system image, and will only restore what is included (see steps 7-9 in STEP TWO below) in the system image back. Be sure to backup anything that you do not want to lose that is not included in the system image backup first.
System Image Recovery STEP ONE System Image Recovery
Only if You Renamed the "WindowsImageBackup" Folder
Note   Note
To be able to have multiple versions of system images saved on the same drive or partition, you would need to rename the older WindowsImageBackup folder from the previously created system image as described in the NOTE box at the top of this tutorial.
If you renamed the WindowsImageBackup folder for the system image version that you wanted to restore, then you will need to do the steps below before you will be able to restore that system image.
1. If you are "Able to Boot" into Windows 7
A) In Windows Explorer, navigate to the renamed (drive letter)\WindowsImageBackup folder location of the system image that you want to restore.
B) If you already have a folder named WindowsImageBackup that is not the system image version that you want to restore, then you will need to right click on it, click on Rename, and type in say WindowsImageBackup-Copy-2 as an example.
C) Now, right click on the renamed system image version (ex: WindowsImageBackup-Copy-1) that you did want to restore, click on Rename, type in WindowsImageBackup an press enter.
D) Go to the STEP TWO section below to do the System Image Recovery.
2. If you are "Not Able to Boot" into Windows 7
A) If you have the system image backup save to an external device, be sure that it is connected now.
B) Open a command prompt at boot.
C) In the command prompt, type diskpart and press enter. (see screenshot below)
D) In the command prompt, type list volume and press enter. (see screenshot below)
E) Make note of the drive letter (ex: E: ) that you have the system image backup saved to.
F) In the command prompt, type exit and press enter. (see screenshot below)
G) In the command prompt, type the E: and press enter. (see screenshot below)
NOTE: Subsititute E: for your actual drive letter at step 2E instead.
H) If you already have a folder named "WindowsImageBackup"
NOTE: This is if you already have a folder named WindowsImageBackup that is not the system image version that you want to restore. If so, you would need to rename it to say WindowsImageBackup-Copy-2 as an example.
  • In the command prompt, type the command below and press enter. (see screenshot below)
    NOTE: Substitute WindowsImageBackup-Copy-2 in the command below with any name in quotes that you would like to rename it to instead.
ren WindowsImageBackup "WindowsImageBackup-Copy-2"
I) In the command prompt, type the command below and press enter. (see screenshot below)
NOTE: Substitute WindowsImageBackup-Copy-1 in the command below with the actual name of your renamed system image folder in quotes that you want to use to restore instead.
ren "WindowsImageBackup-Copy-1" WindowsImageBackup
J) Close the command prompt window. (see screenshot below)
K) Continue on to step 3B in the STEP TWO section below to do the System Image Recovery.
System Image Recovery STEP TWO System Image Recovery
To Do the System Image Recovery
1. If you have the system image backup save to an external device, be sure that it is connected and turned on (powered up) now.
A) Start with either step 2 or step 3 below first.
2. From "Backup and Restore" in the Control Panel while in Windows 7
A) Open the Control Panel (icons view), and click on Backup and Restore.
B) Click on the Recover system settings on your computer link. (see screenshot below)
C) Click on the Advanced recovery methods link. (see screenshot below)
D) Select the Use a system image you created earlier to recover your computer option. (see screenshot below)
E) Select to either create a Back up now, or to Skip it and continue the system image recovery without backing up any of your current files.
NOTE: If you select Back up now, it will take you to step 6 in this tutorial link to create a User and System File back up of your current files first before continuing to step 1F. (see screenshot below)
F) Click on Restart. (see screenshot below)
G) Select a languange to be used for your keyboard input and click on Next. (see screenshot below)
H) Go to step 4.
3. From the System Recovery Options Screen at Boot
A) Boot to the System Recovery Options screen from your Windows 7 installation DVD/USB, or System Repair Disc.
B) Select the System Image Recovery option. (see screenshot below)
4. If you saved the system image backup to a set of DVDs, then insert the last DVD from the set when prompted. If not, go to step 5 for a system image backup on a hard drive.
A) Go to step 7 below.
5. To Use the Latest System Image
A) Select (dot) Use the latest available system image and click on Next. (see screenshot below)
B) Go to step 7.
6. To Select a System Image
A) Select (dot) Select a system image, and click on Next. (see screenshot above)
NOTE: This is if the system image that you want to use is not listed here and is at another location that you wish to choose from instead.
B) Select the location of the backup image for the computer you want to restore from the list, and click on Next. (see screenshot below)
Note   Note
To add a image from a network location, click on the Advanced button, and on the Search for a system image on the network option.
If the drive cannot be seen to select a system image from, then you may need to use the tutorial below to load your SATA or RAID drivers before it will be seen. You would click on the Advanced button, and on the Install a driver option.
SATA Drivers - Load in Windows 8 System Image Recovery
C) Select the date and time of the system image to restore, and click on Next. (see screenshot below)
7. To Do a Full System Image Recovery
NOTE: This option will format everything on each hard disk drive that was included in the system image, then restore them as they were when the system image was created.
Note   Note
Format and repartition disks box:
NOTE: Special thanks to MJF for this addition.
1) Grayed out and selected
You are forced to have the whole disk formatted and repartitioned to match the partition structure of the disk the image was made from. This can occur when restoring an image to a new disk or the original disk with a modified partition structure. Data on other partitions on the disk you are restoring to will be lost.
2) Grayed out and unselected
You are not given the option to format and repartition the disk. This will occur if you are restoring Windows from a partition on the same disk.
3) Not grayed out and unselected
Here you have the option to select format the whole disk and repartition or not. In this case the disk the image was taken from has a matching partition structure to the disk you are restoring the image to. By not selecting the format and repartition option your image will be restored and other partitions untouched such as valuable data partitions.
A) Check the Format and repartition disks box (if not grayed out) and uncheck Only restore system drives box (if available), and click on Next. (see screenshots below)
B) Go to step 10.
8. To Only Restore System Drives in System Image Recovery
NOTE: When restoring to the same disk containing data partitions, the Format and repartition disks option may format the data partitions as well. If this is the case and you have the option to leave the Format and repartition disks box unchecked, then initially attempt your image recovery with the Format and repartition disks box unchecked. If recovery is unsuccessful, repeat the process with the format box ticked.
A) If available, check the Only restore system drives box, and click on Next. (see screenshot below)
B) Go to step 10.
9. To Exclude Restoring Specific Drives in System Image Recovery
NOTE: Since a system image recovery will format everything on each hard disk drive that was included in a system image, this will allow you to exclude specific disks so that specific disk will not be formated or restored.
A) Check the Format and repartition disks box , and click on the Exclude disks button (if not grayed out). (see screenshot below)
NOTE: If the Exclude disks button is grayed out, then the HDD that you are restoring to is empty, or you do not have any disks in the system image that are able to be excluded from being restored.
B) Unselect the drives that you want to exclude from being restored.
C) Click on Next.
10. Click on Finish. (see screenshot below)
11. Click on Yes. (See screenshot below)
12. You will now see this screenshot below.
NOTE: If you have the backup image on DVDs, have them ready. See step 4 above.
13. When it is through, click on Restart Now to finish. (see screenshot below)
NOTE: Your computer will restart and the backup image restoration will be done.
14. If you created a backup in step 1E, then you will now see this option to Restore my files after the computer restarts. (see screenshot below)
16 Apr 2009   #1
nate42nd
Windows 7 Professional x64
I am going to try this tutorial this weekend. I have a small XP partition (and W7 partition) that was included in the Complete PC Image so it should restore it to exactly how it was when I created the image (including the boot manager) right? Has anyone had problems with this messing anything up?
I will post back and let you know how it works. Looks like a good tool.
16 Apr 2009   #2
Brink
64-bit Windows 10 Pro
Hi Nate,
Yes, it should if both the XP and W7 partitions were selected when you created the system image backup.
30 May 2009   #3
nate42nd
I wanted to report back on this. I have a system with XP, Windows 7, and a recovery partition for the XP install. When I created the image with Windows 7 it would not let me choose the recovery partition. Just the XP and W7. I created the image anyway. When it was done I unplugged the USB drive, plugged it back in and booted from the repair disc created by Windows 7. Everything went fine. I found it interesting that ALL 3 partitions were there when done. I don't know if the recovery partition was left there or recovered. Anyway, the "System Image Recovery" works great (again) for anyone wondering. Have a great day.
29 Aug 2009   #4
mcnaugha
Windows 7 Ultimate 64-bit RTM
System Image Recover just let me down
I think I know why I just had a problem and the reason is quite disappointing from my perspective.
I just installed an SSD to replace a 1TB (RAID 0) dual HDD setup. Windows 7 Ultimate 64-bit (RTM) was sitting on the 1TB partition when a System Image was taken.
The SSD was a mere 128GB. System Image Recovery failed and I think it's because the new SSD isn't offering the same size of partition as it was taken from. The actual data content of the image was less than 90GB.
This really disappointed me because I also have Mac experience and I know that Mac system images are not original partition size dependent (when made properly). Apple sensibly designed the technology to essentially care about the data content, not the partition size. That allows one to restore it to any partition with enough capacity for the original data.
Windows 7 not being to restore the data here is really stupid. I'm not really surprised though. MS seems to do things like this quite often. The short-sightedness is shocking.
If anyone knows a command line workaround to this or something, let me know. Thanks in advance.
05 Sep 2009   #5
polycue
Windows 7 Professional x64 x86 VISTA XP 98SE 95 3.x
Do you have to re-activate the restored image?
05 Sep 2009   #6
Brink
Hello Polycue,
If it's restored to the same computer that the system image was taken from, then I do not believe you will need to activate again. It can vary though.
05 Sep 2009   #7
nate42nd
Quote   Quote: Originally Posted by polycue View Post
I have done this twice (to same system like Brink suggested) and have not had to re-activate the restored image.
FYI
05 Sep 2009   #8
SIW2
Vista x64 / 7 X64
For general info (sorry McNaugha - only just seen your post) - there is a workaround.
Use Disk Management to shrink the source partition before creating the image. Then just expand it again afterwards.
05 Sep 2009   #9
mcnaugha
Well I'd figured as much, but I had already taken the HDDs out and couldn't be bothered having to go through it all again just to get the restore to work. I will remember next time. I was able to get my files out of the incremental backups.
System Image vs. System Recovery Disc
Can someone concisely explain the difference between creating a system image versus a system recovery disc? Recently in our office a colleague's computer had a "meltdown". I will create another thread with questions concerning that. I understand that it depends on what causes the "meltdown"...
Backup and Restore
System Image Recovery Error.
Hey guys, just wondered if someone could help me with this? I moved around some of my partitions after creating a system image. When I tried to do the restore to my old layout I got this error message: I have to say I never used to get this error before when I moved my partitions...
Backup and Restore
System Recovery Image
I can see that there is a lifetime of information about recovery images so this has probably been covered. I have my system set up and running exactly the way I want it. Can I create a system Image on a set of disks that will recover/restore/re-do my system right back to the way it is? Given...
Backup and Restore
Hello folks. I have a book that says before performing a System Image Recovery I have to put in my Windows 7 disc and totally re-install Windows 7 before even beginning the Restore function mentioned in your tutorial. Is this necessary?
Backup and Restore
System Recovery from image
I put a system image on a MY Book external hard drive and made a recovery DVD boot disk after installing MSW 7 64 upgrade from Visita 64. When I made the image I had a three Seagate hard drive RAID 0 configuration. Everything operated normally for a month until two of the Seagates crashed at the...
Backup and Restore
System image recovery question
Hi all, have a small question - at present I have windows 7 on 1 drive (a), old xp on another drive (b) which has 2 partions and a 3 rd drive (c) in an esata bay. I have backed up windows 7 from drive (a) onto the external drive (c). I want to install windows 7 over the xp installation (b) with 2...
Backup and Restore
