How to Create a "Gadgets" Shortcut in Windows 7
This will show you how to create or download a Gadgets shortcut that opens to the same location when you right click on the Desktop and click on Gadgets.
EXAMPLE: Gadgets
OPTION ONE
To Download a "Gadgets" Shortcut
1. Click on the download button below to download the
Gadgets.zip file.
2. Click on Save, and save the .zip file to the desktop.
3. Open the .zip file and extract the Gadgets shortcut to the desktop
4. Right click on the
Gadgets shortcut, and click on
Properties,
General tab, and on the
Unblock button. (See screenshot below)
5. You can now
Pin to Taskbar or
Pin to Start Menu this shortcut,
assign a keyboard shortcut to it, or move it where you like for easy use.
6. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
OPTION TWO
To Manually Create a "Gadgets" Shortcut
1. Right click on a empty area on desktop, and click on
New and
Shortcut.
2. Copy and paste the location below into the location area, and click on the
Next button. (See screenshot below)
%windir%\explorer.exe shell:::{37efd44d-ef8d-41b1-940d-96973a50e9e0}
3. Type
Gadgets for the name, and click on the
Finish button. (See screenshot below)
4. Right click on the new
Gadgets shortcut on the Desktop and click on
Properties.
5. Click on the
Shortcut tab, then click on the
Change Icon button. (See screenshot below)
6. In the line under "Look for icons in this file", copy and paste the location below and press
Enter. (See screenshot below)
%ProgramFiles%\Windows Sidebar\Sidebar.exe
7. Select the icon highlighted in blue above and click on
OK. (See screenshot above)
NOTE: You can use any icon that you would like instead though.
8. Click on
OK. (See screenshot below)
9. You can now
Pin to Taskbar or
