How to Pin the Control Panel to the Taskbar in Windows 7
InformationThis will show you how to pin the Control Panel to the Windows 7 taskbar as a icon.
EXAMPLE: Control Panel Unpinned and Pinned from the Taskbar
OPTION ONETo Pin Control Panel to Taskbar
1. Open the Control Panel.
2. Right click on the Control Panel icon on the taskbar and click on Pin this program to taskbar. (See screenshot below) 3. When done, you can close the Control Panel.
OPTION TWOTo Unpin Control Panel from Taskbar
1. Right click on the Control Panel icon on the taskbar and click on Unpin this program to taskbar. (See screenshot below)That's it,
Related Tutorials
- How to Pin or Unpin Program Links to the Windows 7 Taskbar
- How to Enable or Disable Windows 7 Taskbar Pinned Programs
- How to Add or Remove a Default Desktop Icon in Windows 7
- How to Pin Your User Files Folder to the Windows 7 Taskbar
- How to Pin the Recycle Bin to the Windows 7 Taskbar
- How to Set a Default Control Panel View in Windows 7 and Windows 8
- How to Change the Windows 7 Pinned Windows Explorer Taskbar Icon Open To Target
- How to Pin Computer to the Windows 7 Taskbar
- How to Change Windows 7 Default Control Panel Icons
- How to Show or Not Show All Folders in the Windows 7 Navigation Pane
- How to Create a Control Panel All Tasks List Shortcut in Windows 7
- How to Add or Remove Control Panel from the Windows 7 Navigation Pane
- How to Add or Remove "Control Panel" from Desktop Context Menu
- How to Enable or Disable the Control Panel in Vista and Windows 7
