Startup Repair
Page 16 of 18 FirstFirst ... 61415161718 LastLast
  1. Posts : 72,058
       #150
    Great news. Details please.
  2. Posts : 925
    Windows 10 Pro
       #151
    EasyBCD solved the problem, I had to pay $40 for the Repair DVD. When I saw on screen BootMGR Repaired, I knew it was fixed.
    Formatting the drive etc, was all not working, no matter what rescue DVD I had or USB drive I had, nothing worked, I was denied at every angle. Bootrec didn't solve the problem, it was a week I won't forget.
    I need to find a valid, robust, partition software that won't cause this mess again.
  3. Posts : 72,058
       #152
    I'm surprised that wiping the drive didn't let you clean install, but thank you for posting back with your results.
  4. Posts : 925
    Windows 10 Pro
       #153
    I couldn't wipe the drive, it wouldn't allow me, from my own Windows7 discs, to the Digital Rivers ISO boot discs, all the way to any other software programs boot disc, I was plain out denied. You always want to go with free options first, which is what I did, I was skeptical about the BCD solution, but it does work.
    I recommend trying all solutions from this thread, which are your cost free solutions. If those don't work, then you will have to pay $40 for BCD and let it fix it for you, once you are in that much of a bind, what is left !
  5. Posts : 21,004
       #154
    Hello Shawn have got an oldish (not too old) XP machine that has thousands of dollars worth of CAD software on it and it stalls at the welcome screen normal boot and the starting Windows in safe mode any guise. Have checked the machine for obvious hard ware failure and cannot find any.
    So could your tutorial be used in some way on this problem please?
  6. Posts : 72,058
       #155
    Hello John,
    I'm sorry, but this tutorial wouldn't apply to XP.
    You might see if you may be able to do a system restore at boot in XP to hopefully go back to before this happened.
    http://support.microsoft.com/kb/306084/
  7. Posts : 21,004
       #156
    Ok thanks Shawn I didn't think it would work but it was a suggestion to me. I ma using the OS disk and the Recovery Console right now except the fellows have gone to lunch and I need the admin password
  8. Posts : 20
    New South Wales
       #157
    Reboot to CD or HD?
    Hi and thanks for the great info.
    When the system restarts should it go back to the repair CD or to the HD?
  9. Posts : 72,058
       #158
    Hello Negabuff, :)
    It should boot to Windows if successfully fixed.
  10. Posts : 759
       #159
    Hi, Brink,
    My explorer.exe failed and my system could not boot in normal mode. it could be started in safe mode. I tried to register the dll command. I went to elevated command prompt and issued the cmd. regsvr32 exploreframe.dll as a solution given to re register the dll. But it came with failure such as module could not be loaded errors.
    Then i put my dvd and opted startup repairs, it done something and i could now boot to normal windows. My question is why cannot i register the dll, if it is working, explorer.exe, is working , in normal mode. What the startup repair done to repair . how to find the repair log. It says 0x0 error in all the startup repairs itemwise. Would you through some light on this aspect and also how to fix windows explorer from freezing. pl
