Startup Repair
Page 5 of 18 FirstFirst ... 3456715 ... LastLast
  1. Posts : 72,052
       #40
    Wandering Flame said:
    Where do I check if I have Start-up Repair on my hard drive? Would it be in my computer next to my C drive?
    In additon to Jonathan's post above, see the link in step of this tutorial on the first page. It, along with the other steps in this tutorial, show you how to get to the Startup Repair option.
  2. Posts : 3
    windows 7
       #41
    my computer, Dell XPS M2010, does startup repair all time.. it have done it 20 times, i can't stop it.. it just does it over and over all time.. how to stop it.. ? is there any way to.. ?
    would be nice to get help..
    Thanks from Tmac635
  3. Posts : 13,354
    Windows 7 Professional x64
       #42
    Thanks from Tmac635
    Can you tell it to startup normally?
    You may also try running the repair from the installation disc.
  4. Posts : 3
    windows 7
       #43
    Thanks from Tmac635
    I did not do anything.. it began itself..
    I just want to stop it..
  5. Posts : 13,354
       #44
    Try running the startup repair from the repair disc instead. Maybe that will fix whatever issue is triggering the repairs, so they stop appearing.
  6. Posts : 3
    windows 7
       #45
    Yeah, but how ..? It's doing startup repair all time.. I'm nnot able to insert a disk and run it..
    Computer do start up, and then startup repair begins and when it's done computer shut down and when I start up next time it does the same thing, it have done it 20 times now..
  7. Posts : 11,840
    64-bit Windows 8.1 Pro
       #46
    At this point, I would do a clean install...
  8. Posts : 11,408
    ME/XP/Vista/Win7
       #47
    If you have the Dell diagnostic tools CD, try running it.
    Check your ram.
    Memory Diagnostics Tool
    Memtest86+ - Advanced Memory Diagnostic Tool
    Check your HD.
    Disk Check
    Check with a hard drive diagnostic tools.
    Hard Drive Diagnostics Tools and Utilities (Storage) - TACKtech Corp.
  9. Posts : 3
    Windows 7 / windows XP
       #48
    Help
    Hey I was trying to install this one theme and this dude was helping me over team viewer and I just left for like 2 mins and when I came back he had deleted me of msn and he had deleted some of my system 32 files. I rebooted my pc hoping the startup repair would start and fix it but it didn't so I decide to put the disc into my pc and run the startup repair on there it came up with the error saying that I must unplug the media stuff from my pc and I have tried to do it 6 times and no luck. Can someone pls help me I would really appreciate it.
  10. Posts : 13,354
       #49
    Welcome to SF!
    I suggest a system restore to get to a point before the troubles.
