System Restore
Page 14 of 15 FirstFirst ... 412131415 LastLast
  1. Posts : 3
    Windows 7 professional 32 bit
       #130
    Sysyem Restore Error
    i made a a mistake once of forgetting to uncheck the box for 'always use this program to open this kind of file' and now all my programs attempt to open in adobe reader. i tried fixing this error with system restore but i always get a response that system recovery failed even when i switch off my antivirus. is there anything i can do to reverse the situation or fix system restore?
  2. Posts : 72,037
       #131
    Hello Sapphyblud, and welcome to Seven Forums.
    If you like, you could download and merge the .reg files for the listed .lnk (LNK) and .exe options in the tutorial below to restore their default associations. This may also fix system restore if related to the association issue. :)
  3. Posts : 10,796
       #132
    What file extension did you open with acrobat reader and forgot to uncheck "always use this program to open this kind of file"?
  4. Posts : 3
       #133
    .lnk
  5. Posts : 72,037
       #134
    sapphyrblud said:
    .lnk
    In that case you could do what I posted above for .lnk files to fix this. :)
  6. Posts : 3
       #135
    Brink said:
    sapphyrblud said:
    .lnk
    thanks. it works
  7. Posts : 72,037
       #136
    You're most welcome. :)
  8. Posts : 33
    Win7 Pro x64
       #137
    System Restore vs. Program Uninstaller
    I have a System Restore "effectiveness" question for any expert that cares to respond.
    If I create a System Restore point (in Win 7 Pro) before I install a program that includes drivers (Intel PRO/Set Wireless Software, for example), and I later want to completely remove/uninstall the program and its drivers.....
    Which is more effective at removing all traces of the program and its drivers (Program Files, ProgramData, Registry entries, etc.):
    1.) using Programs and Features "Uninstall", or
    2.) restoring the System Restore point that was created before the application was installed?
    Thanks.
  9. Posts : 72,037
       #138
    Hello Toby,
    If the program is fully compatible with Windows 7, then it should fully uninstall using Programs and Features.
    With that said, you know as well as I do, that not all programs will always uninstall fully and cleanly without having some remnants left behind. Doing a system restore using a restore point dated before you installed the program will restore Windows back to how it was when the restore point was created leaving no trace of any programs installed after the date of the restore point.
    Hope this helps, :)
  10. Posts : 33
    Win7 Pro x64
       #139
    Hi Brink,
    Thanks for the quick reply. I appreciate your help.
    Toby
