Desktop Background - Remove Picture Location History
    How to Remove the Desktop Background Picture Location History in Windows 7 and Windows 8
    This will show you how to either reset to default or remove a folder in the desktop background picture location drop down list in Personalization in Windows 7 or Windows 8.
    EXAMPLE: Desktop Background Picture Location
    Desktop Background - Remove Picture Location History-example.jpgDesktop Background - Remove Picture Location History-default.jpg
    OPTION ONE
    To Reset Picture Location to Default using a REG Download
    NOTE: This option will reset the picture location drop down menu list back to only having the default folders removing any folders that you have added (Option Three below) by browsing to them.
    1. Click on the Download button below to download the file below.
    Reset_Desktop_Background_Picture_Location_History.reg
    2. Save the .reg file to your desktop.
    3. Double click/tap on the downloaded .reg file to merge it.
    4. Click/tap on Run, Yes (UAC), Yes, and OK when prompted.
    5. When finished, you can delete the downloaded .reg file if you like.
    6. Close and reopen Desktop Background in Windows 7 or Windows 8 to see the change.
    OPTION TWO
    Reset or Remove a Picture Location Through Registry
    NOTE: This option will allow you to either manually reset the picture location drop down menu list back to only having the default folders removing any folders that you have added (Option Three below) by browsing to them, or only remove one or more folders listed in the picture location drop down menu list.
    1. Press the Windows + R keys to open the Run dialog, type regedit, and press Enter.
    2. If prompted by UAC, then click/tap on Yes to approve or type in the administrator's password.
    3. In regedit, navigate to the location below: (see screenshot below)
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Wallpapers\Images
    4. To Reset Desktop Background Picture Location History
    A) In the left pane of regedit, right click on Images, and click/tap on Delete. (see screenshot above)
    NOTE: Images is restored automatically the first time that you add (Option Three below) a folder by browsing to.
    B) Click/tap on Yes to confirm deletion. (see screenshot below)
    C) Go to step 6.
    5. To Remove a Listed Folder in Picture Location
    A) In the right pane of Images, right click on one of the listed ID# (0-9) that you want to remove, and click/tap on Delete. (see screenshot below)
       Tip
    The top 4 Windows Desktop Backgrounds, Pictures Library, Top Rated Photos, and Solid Colors default folders will not be included in the listed ID#'s.
    The folders that you added will be listed in order under the default ones above with the same ID# order listed in the registry.
    NOTE: If you made a mistake and deleted the wrong picture location folder, then you can add it back by just browsing to and selecting it in Option Three below.
    C) Repeat steps 6A/B if you wish to removed another added picture location folder.
    6. Close regedit.
    7. Close and reopen Desktop Background in Windows 7 or Windows 8 to see the change.
    OPTION THREE
    Add a Picture Location Through Desktop Background
    1. Open Desktop Background in Windows 7 or Windows 8 in Personalization.
    2. To the right of Picture location, click on the Browse button. (see screenshot below)
    3. Navigate to and select the folder you want to be added to the picture location history, and click/tap on OK. (see screenshot below)
    4. It will be listed in the Picture location drop down arrow box.
  1. Posts : 17,322
    Win 10 Pro x64
    AWESOME Shawn! That is another great tutorial, That bugs me seeing those old ones there. You're the Man.
  2. Posts : 72,050
    Thank you Derek. You're most welcome. Yeah, that had bugged me to. :)
  3. Posts : 2
    Thank you, this really helped me out! :)
  4. Posts : 72,050
    You're most welcome Endless, and welcome to Seven Forums. :)
  5. Posts : 2
    Thank you :).
  6. Posts : 55
    Windows 7 Home Premium
    good job but do you know how to change the: how the pointer looks history
    post a tutorial if you do
    thanks Jack
  7. Posts : 72,050
    Hello Jack,
    You should be able to just select a "Mouse Pointer" scheme that you had saved, and delete it to remove it from the list. You cannot delete the default schemes though.
  8. Posts : 3
    Windows 7 Professional 64bit OS
    Can no longer add folder
    So I know how to do whats described, yet somehow (in the last two weeks) I have lost the ability to add folders.
    I Browse to one(any folder anywhere) and select it, and it doesn't work. Nothing happens, the folder is not added?? Any ideas?
    How can I make it work again?
    or
    How can I manually(regedit) add in a new folder location? ++
    Full add min rights etc.
  9. Posts : 72,050
    Hello Debellator, and welcome to Seven Forums.
    Interesting. Does the folder that you selected contain any images in it? Could you post a few screenshots of what you are seeing instead to see if something may stand out?
