System Reserved Partition - Delete
Page 7 of 8 FirstFirst ... 5678 LastLast
  1. Posts : 72,046
       #60
    Go ahead and connect E: back, and post a screenshot of your Disk Management to see what the issue may be. :)
    Disk Management - Post a Screen Capture Image
  2. Posts : 4
    Win 7 Home Premium
       #61
    Attached
    Attached Thumbnails Attached Thumbnails System Reserved Partition - Delete-disk-management.png
  3. Posts : 72,046
       #62
    Ok. Mark C: as active, remove disk 0, and try the startup repair again to see if it's able to repair the boot manager after a few runs.
    In addition, double check your BIOS settings to make sure that C: is listed first in the boot priority, or second after the CD/DVD drive.
  4. Posts : 4
    Win 7 Home Premium
       #63
    That did it. Rock and rolla. Thanks!
  5. Posts : 72,046
       #64
    You're most welcome. :)
  6. Posts : 25,847
       #65
    I have a question or 2.
    1. If one encrypts their C drive and then removes the the System Reserve will they be able to get back to the encrypted C drive?
    2. If a computer has a finger print recognition program or a program that works in that fashion will removing the System Reserve have a effect?
  7. Posts : 72,046
       #66
    Hey Jack,
    Q1) The system reserved partition is required to encrypt an OS drive with BitLocker. You would need to decrypt the OS drive before removing the system reserved partition.
    Q2) I don't have a fingerprint reader to test with, but if it saves on or uses the system reserved partition, then it could be an issue if you didn't remove the fingerprint first.
  8. Posts : 25,847
       #67
    Thank you Shawn.
    What made me think of such questions was some people are so concerned about removing that little 100mb partition they might not think far enough ahead before they remove it. That 100mb being removed could cause one huge head ache.
  9. Posts : 72,046
       #68
    You got that right.
  10. Posts : 4
    Windows 7 Ultimate x32
       #69
    Hi. I have the same problem with unnecessary partition. I tried step by step how its written in first post. But when i do step 6. Enter delete partition override. Its don't let me do that. Then i looked in Disk Management and was wondering if partition (F:) 100 MB is the same as System Reserved Partition 100 MB. Attached screenshot. And if its different, how can i delete it? Installed fresh Windows 7 Ultimate x32 and this partition is really annoying me hope for someone to respond.
    Thank You!
    Attached Thumbnails Attached Thumbnails System Reserved Partition - Delete-partitionf.jpg
