System Reserved Partition - Delete
Page 8 of 8 FirstFirst ... 678
  1. Posts : 25,847
       #70
    System reserve shouldn't have a drive letter.
  2. mjf
    Windows 7x64 Home Premium SP1
       #71
    RKungs said:
    I tried step by step how its written in first post. But when i do step 6. Enter delete partition override. Its don't let me do that.
    Did you do Step 1. That is, are you booting from a System Repair or Installation CD/DVD.
  3. Posts : 4
    Windows 7 Ultimate x32
       #72
    Ya! that's why i wondering how to delete this partition.Is it System reserved or not.How to delete it? Is there way without re-install windows delete this partition.!? No offence Layback Bear but how exactly your post answer to my questions? ;o
  4. Posts : 4
       #73
    Yes! I did everything like in manual and from installation CD. : )
  5. mjf
       #74
    Yes it is the system reserved partition. If you followed the tutorial exactly then I don't know why you are experiencing problems. As you probably know, using Diskpart you have to be very precise.
    Here is another approach
    Bootmgr - Move to C:\ with EasyBCD
    A final point. I have system reserved on 2 builds and decided not to bother on a 3rd build. Unless it's causing you grief with say Windows inbuilt system imaging or taking up a needed partition slot then I'd just leave it alone.
  6. Posts : 4
       #75
    I am not pro in those things, but i know how to follow tutorials. Normally i find out by myself how to deal with problems witch i get during the time i use my PC/Laptop. But this time i just don't understand why it shows Partition F instead of System reserved. I will try one more time tomorrow do this steps to delete reserved partition.
    Thanks for this other tutorial i guess i will find it useful sooner or later.
    This third partition isn't bothering me too much, just was wondering why everyone can easily delete but i have problems with that. I like at least to try fix this small things..witch sometimes annoying me ;D
  7. Posts : 25,847
       #76
    Maybe this will be helpful for you.
    Drive Letter - Add, Change, or Remove in Windows
  8. Posts : 2
    It is necessary to delete the primary partition "System" comes from the my new laptop manufacturer in order to create logical parts for backup files. I have followed what King told with either the 'system repair disk' or 'installation disk' thumb drive, but there is nothing come out with shift-F10 pressed after the language options screen appeared. It means cannot get into the diskpart mode. How can I keep on things go as said?
