Unidentified Networks - Set as Private or Public
Page 2 of 7 FirstFirst 1234 ... LastLast
  1. NoN
    Brink said:
    NoN,
    No, that was just an example above. You can have any type of connections that you like and merge them.
    Thanks for your respond Shawn, I think i have set it up right but decided not merging those networks.
  2. Posts : 72,058
    You're welcome. :)
    Yeah, merging them is pretty much pointless unless the internet connection comes from two separate independent sources (ex: modems). That way if one modem fails, the other picks up.
  3. Posts : 5
    Windows 7 Home Premium
       #12
    thank you very much for the annswer and sorry for my late answer.
    Just for my understanding: After adding the information to the regestry (e.g. by the Set_Unidentified_Networks_Private script) all new networks should be automatically defined as home network. There should be no popup or anything else. Is this right?
    Heres the screenshot of my reges´try key:
    Thank you in advance
    Alex
    Attached Thumbnails Attached Thumbnails Unidentified Networks - Set as Private or Public-screennetworks.png
  4. Posts : 72,058
    Hello Alex,
    It will only automatically set "unidentified" networks as a Home network. You will still get the pop-up when you create a new network to ask what type of network you want it to be.
  5. Posts : 5
       #14
    thank you very much for your answer. This was helping me a lot. Is there a way to also stop this window popping up? The problem is e.g. when putting my small backup system (With Windows 7 Pro) to a unknown network and wants to log on it by remote desktop, then I only could do it after confirming home network on the system. If you have a monitor in use - no problem but without you do not have a chance :-(
    Thanks in advance and Regards,
    Alex
  6. Posts : 72,058
       #15
    Alex,
    I'm not aware of a way to do so, but you might post that in the "Network & Sharing" forum to see if someone may know of a way.
  7. Posts : 2
    Windows 7 Home Premium 64bit as VM
       #16
    hey, can i have a tutorial for 7 home premium? kthnxbi
  8. Posts : 72,058
       #17
    Hello Cyber, and welcome to Seven Forums.
    The OPTION TWO section in the tutorial with the REG files will work in all editions of Windows 7. :)
  9. Posts : 2
    Windows Home Premium 64bit
       #18
    Hello Brink,
    Thanks for the post this solved a big problem I was having with my Window 7 Pro 64bit.
    I'm still having a problem with Windows Home Premium 64-bit. I did option 2 and that change from a Public to a private network. but I still can't see the Network shares from a Linux.
    From the Linux machine a I can see all my PC's (running XP, Vista, Windows 7 Pro 64.bit) but I can't seem to see the Windows 7 Home Premium 64bit machine. Any ideas?
    JW
  10. Posts : 72,058
       #19
    Hello JW, and welcome to Seven Forums.
    I'm happy to hear that this tutorial was able to help you change it to a private network, but I would recommend to create a new thread on the other separate network shares from a Linux in the Network & Sharing forum area to get the best help on it. :)
