#30
well i tried that but no change i cant seem to change the unidentified network to home network from public network is it because its a duel wireless router and i have the 5Ghz switched off?
You might see if using the tutorial to set unidentified networks to be Private will change it.
Nar, it wouldn't be the 5Ghz band for the issue.
Are you having any issues with being connected to either?
Does it have unidentified networks listed when you only have one type of network connected?
For example, turn off wireless while using ethernet, and vice versa.
I wish I could help more Brian, but I reached my knowledge limits about networking on this as well.
i tried to change it to private as in your tutorial but it never changed the networks are connecting fine
okey dokey not to worry brink thanks i will research it to me it means the computer is seeing two networks while using ethernet i will get back to you if i work it out thanks again :)
when you switch out new product they the ISP have to make sure they have it in there system they can switch out all the new stuff they want but in the end they need to make sure it is the same equipment they have logged into there service
I am saying this because they did this to me and my family I asked to change my service plan and to change who was paying for it they gladly sent me on my way but they never mentioned on there end they have to make sure the Model numbers matched the equipment there managment services said you are using when it was all said in done they had to re input router and modem information in there systems to work properly and mind you same house same line just better plan and billing name changed
I know it sounds way out there but that is exactly what we had to do to get it corrected because the ISP failed to mention they had to have the devices input to there system as well
