Shut Down -Speed Up
Page 3 of 10 FirstFirst 12345 ... LastLast
  1. Posts : 72,043
       #20
  2. Posts : 8,375
       #21
    Now you have to find something that really speeds up the loading time for Vista to provide over there. I just got done looking over a laptop with 1gb of memory bought new recently with Vista preinstalled on it! A friend bought it new for his better half and wanted to know why things ran slow........ You know the answer to that one! I emailed a link for a pair of 1gb dimms to replace the 512s!
    The reduction to 12000 on Vista even on the VPC proved worthwhile! Once you pause at the shutdown screen for a few ..............zoom!!! to the restart!
    I found the same 20000 value in the XP mode registry as well. I lowered that one down to the 8000 mark and should see the same results there!
    (Gosh I could have used this when the XP/Vista dual boot was on! )
    Update: I went ahead and lowered it down even further to the 3000 mark. You'll notice a big difference in how fast you see the post screen come up if you are not simply shutting everything down. The shutdown goes a lot faster there too!
    Attached Thumbnails Attached Thumbnails Shut Down -Speed Up-xp-wait2kill.jpg
    Last edited by Night Hawk; 02 Jul 2009 at 01:09. Reason: another image to add and.... an update
      My Computers
  3. Posts : 35
    Windows 7 x64
       #22
    thanks, nice easy little tweak.
  4. Posts : 72,043
       #23
    You're welcome Jess. :)
  5. Posts : 8,375
       #24
    It was definitely a great catch on that one! So far the low 3000 setting has proven itself!
      My Computers
  6. Posts : 5
    windows 7
       #25
    will try this out
  7. Posts : 8,375
       #26
    It's worth a look! In fact I just dropped it again down to the 1000 mark on the host install of 7 to see how that goes.
      My Computers
  8. Posts : 6
    Windows 7 Professional
       #27
    huh .., it looks ok and very simple, but then i have a question, why MS don't make (for e.g 2s.) it as default settings?
  9. Posts : 72,043
       #28
    Hello Aven, and welcome to Seven Forums.
    The time period is to allow programs enough time to close properly when Windows 7 closes them to shutdown. Some programs do no need extra time, or if you do not have anything running, then you do not need as much wait time. Microsoft is just playing it safe with the amount of default wait time. That's all.
  10. Posts : 8,476
    Windows® 8 Pro (64-bit)
       #29
    I keep the waittokill value at 200.
