#60
Hello Demonicon,
You most likely have some app that is running in background not wanting to shut down properly. This tutorial will not affect that. You could check in Task Manager (CTRL+Shift+ESC) to see what "Applications" or "Proccess" for a app are listed before shutting down to help narrow down which one may be the cause.
What do you have the wait time set as?
If you like, you could give the tutorial below to use a force shut down shortcut to see if that may help shut down your computer faster until you find the app causing the delay.
