Shut Down -Speed Up
Page 9 of 10 FirstFirst ... 78910 LastLast
  1. Posts : 72,043
       #80
    You're most welcome John. :)
  2. Posts : 26
    Microsoft Windows 7 Home Premium 64-bit
       #81
    Thanks for the tutorial. I used option 2 and set to 2000. No problems.
  3. Posts : 7
    Windows 7 Ultimate.
       #82
    THANK YOU!
    This has always bugged me: waiting & waiting for the reboot.
    The perfect solution!
  4. Posts : 21,004
       #83
    Hmm I have set mine as low as 5 and have no problems either.
    Did you try the other parts of the tutorial that Brink did this comes from?
    Optimize Windows 7
  5. Posts : 2
    Windows 7 Ultimate 64 bit
       #84
    Thank you!
    Last edited by archaeopteryx; 26 Feb 2014 at 10:44. Reason: My original post was moronic
  6. Posts : 260
    Windows 7 Ultimate 64bit
       #85
    Dinesh said:
    My boot time with waitokill value at 12000:
    Attachment 10426
    My boot time with waitokill value at 120:
    Attachment 10427
    How do you do this? (variables in a msgbox / evt string > msg)?
  7. Posts : 260
       #86
    I imagine that to do something like this
    you need to pass some variables.
    Some info here, but it's a bit above my level of understanding
  8. Posts : 21,004
       #87
    Jonny mate in the tutorial by Brink https://www.sevenforums.com/tutorials/717-shut-down-speed-up.html just as in Option 2 in the registry but as a precaution do this first just in case you do something wrong
    https://www.sevenforums.com/tutorials/4230-registry-backup-restore.html I always do this after a clean install and before tweaking the registry - not that Brinks tutorial will do anything untoward but you just might hit the wrong key or button and if things go awry then you can just merge the registry settings back and start again it is a good safety net.
    I have mine set to 5 but you can set it to what you like 20 50 100 etc
    Same goes with the menu start up in the Optimise tutorial see point 16 in https://www.sevenforums.com/tutorials/11728-optimize-windows-7-a.html it will speed the start up for you, in fact most of the tweaks will. But do that backup FIRST!!
  9. Posts : 260
       #88
    That doesn't answer my question
    How do you configure the event viewer's action for an event (103 etc from Microsoft-Windows-Diagnostics-Performance/Operational) to reference the boot / reboot info, like in the image above?
  10. Posts : 72,043
       #89
    Hello Jonny,
    Here you go: Restart Time
