Restart Time
Page 3 of 11 FirstFirst 12345 ... LastLast
  1. Posts : 8
    Windows 7 Professional x64
       #20
    After the reboot, I dont' get the popup showing my restart time.
    I get my login page, showing my login (as admin) and my other login (for my PostgreSQL)
    Ah, fixed it. While I was making the tweaks it started working... just dunno which one it was .
    53 seconds so far... not done tweaking though
    Edit: had to disable the logon screens, so it goes directly to my desktop upon bootup...
    Down to 43 seconds, but was hoping for under 15
    Last edited by ProsperousOne; 07 Feb 2010 at 21:27. Reason: removed link and merged posts
  2. Posts : 1
    Windows 7 Ultimate
       #21
    My pc restarts in 141 seconds.
  3. Posts : 17
    Microsoft Windows 7 Ultimate build 7600 32bit
       #22
    msconfig update
    danielinterius said:
    Brink said:
    Hello Daniel, and welcome to Vista Forums.
    Thank you. :)
    Now, 40 seconds.
    YouTube - 40 seconds restart time with windows 7 x64 rc build 7100
    I've seen your vid i must say im impressed and jealous bit but if you go to start and type in 'msconfig' and run it go to second tab and click 'no gui boot' and change 30 seconds to 3.
    Also go to advanced or something like that and select all cores to speed it up its just a minor windows mistake.That will speed it up even more.
  4. Posts : 3
    Windows 7 Ultimate & Windows vista.
       #23
    thank you, very useful.
    if my restart time is 62 sec, it's good?
  5. Posts : 1,223
    Win 10 x64 Pro x64 / Ubuntu 15.10 x64
       #24
    If that's with normal mechanical drives (not SSD), a non-RAID setup, or standard speed CPU (not overclocked); then yeah, that's a pretty awesome score...
  6. Posts : 6
    Windows 7 x64 Ultimate RC Build 7100.0.090421-1700
       #25
    Thank you. :)
    Now, 40 seconds.
    I can assure you, that I have done everything possible, to get the absolutely lowest restart time. :)
  7. Posts : 17
       #26
    well in that case sorry for interruption danielinterius
  8. Posts : 761
    Windows 2000 5.0 Build 2195
       #27
    maciacia1 said:
    second is not bad but first one ive done everything possible to slow it down and i guess thats a record
    It's simple, really. Enter BIOS after restart. Go to bathroom. Have Lunch. Have snack. Watch TV. Stretch. Take a bath. Go out walk. Go back in. Exit BIOS. Voila, it'll be an awesome restart time
  9. Posts : 6
       #28
    Interuption?
    What do you mean by that?
    As far as I know, you have not interrupted me in any way?
  10. Posts : 6
       #29
    Better results.
    Now I tried the script with usb-functions disabled in bios.
    38 sec.
