Convert Video or Audio files with Format Factory
    It is sometimes required to convert a video or audio file to another format - for example if you want to use it in a Power Point slideshow where you need WAV audio files or you want to play a video downloaded from the internet for which you do not have the right codec. In those cases I suggest you use Format Factory. The program is very easy to use and you can convert in three simple steps.
  1. Posts : 3
    Windows 7 Professional; Windows 7 Starter
    Ahh, finally an excuse to convert my .mp4 and .m4v files to avi... assuming it supports .m4v?
