Icons - Change Using Resource Hacker
Page 10 of 10 FirstFirst ... 8910
  1. Posts : 20,583
    Win-7-Pro64bit 7-H-Prem-64bit
       #90
    Thanks Archie,
    I made the icons 66x66 but CorelDraw's ico files are not transparent for the round corners but did import the png's to gimp and it's ico options do make them transparent :)
    Still thinking of a start button
    What are the file locations for 125dpi on 64bit :/
  2. Arc
       #91
    125 dpi start button images are in C:\Windows\explorer.exe. The image resources are Bitmap 6802, 6806 and 6810.
  3. Posts : 3
    Windows 8.1 64 bit
       #92
    I follow this tutorial, but when I get to the appropriate step, I find no "Replace Resource" option on the right-click menu (I find "Replace Icon" instead). I tried using "Replace Icon", but it only allows the loading of one icon file at a time, and the resource I am trying to change has many icons within it.
    Do I need an older version of Resource Hacker? Are there different steps for the latest version of Resource Hacker?
    Thanks for any help.
  4. Posts : 2
    I'll be in charge of Windows 7 Welcome to the screen of which the .dll was editing the wallpaper
