Icons - Change Using Resource Hacker
Page 3 of 10 FirstFirst 12345 ... LastLast
  1. Arc
       #20
    Hi Diko !
    Welcome to seven forums !
    May you please describe the problem in detail ?
  2. Posts : 2
    Hi!
    I replaced a few icons especially folder icons in imageres.dll as you mentioned. But it's not applied on all folders. Some of them have old icon while others have the new icon. When I use large icons, they all have the new icon. Other types of icons such as desktop and drive icons that i replaced have the same problem. How can i solve this problem? Thanks a lot.
  3. Arc
       #22
    MYSTIC said:
    Hi!
    Try this Icon Cache - Rebuild
    Wish you good luck.
  4. Posts : 2
    Arc said:
    MYSTIC said:
    Hi!
    Wish you good luck.
    Thanks a lot. That's Okay now. :)
  5. Arc
       #24
    You are most welcome
  6. Posts : 36
    win 7 pro
       #25
    problem occured after icons-change using resourse hacker
    ARC
    After following your tutorial to change the icon for recycle bin, I restarted my computer and log on screen turned black. I did not show username and password field for me to fill in.....
  7. Arc
       #26
    Startup Repair Try this first . If it doesnot work, please make me know .
  8. Posts : 36
    win 7 pro
       #27
    It helps,tx. I got my computer back.
    I really dont know why startup was crashed and is there another way to change the icons for files and folders in win 7 because I am only one to get this trouble for this tutorial.
    Tuan Tran
  9. Arc
       #28
    Tuan Tran
    Nice to know that you get it back, pal I hope you have followed all the steps carefully, specially taking ownership .
    I'd suggest you to Backup Complete Computer - Create an Image Backup first (in case of any severe crash, it will help you to get your things back), and follow the steps again . Hope in the next time everything would be ok
  10. Posts : 36
    win 7 pro
       #29
    Tuan Tran
    I have just tried the tutorial again and i got the message "Out of system resource" after entering replacing the original icon with my own icon. Did it happen to you when you tried it.
    Tuan Tran
