#20
Its ok. I'm confused too./ :P
Do you have a download for that one you made in the tutorial? Great tutorial by the way
I've made my own orbs... well, cubes and I guess I might've done the sides a bit too big, even though I made the canvas size the right size. They came out looking great and I tested them, but unfortunately the top gets cut off and doesn't show past the top of the bar. You can take a look if you like. Any advise or help is appreciated =]
Just had a quick look at the PSD in the attached ZIP file; but before we get to that, one very important part I think you missed:
If you try and keep the edges of your button within these boundaries (about 9 to 10px from the background edges in a 54x162px size) then it'll fit better on your taskbar.WarningDon't let the effects go too far off the the sides! The taskbar isn't as big as the 54x162px Start Orb images will make you think... Try and keep the majority of your Orb within about 9 or 10 pixels of the border of each block. Below is an example of a 9px border around my Orb:
Other than that, when I checked the 'Channels' list, there was no Alpha channel. You missed a few steps though, I've attached some images below:
Step 1
Merge the layers of your button states (normal, hover, clicked) so they can be selected properly in the next step.
Step 2
Select the pixels for your button; either hold ctrl (or 'Command on a Mac) and click the layer preview, or right click the layer preview and click 'Select Pixels'.
Step 3
Create the Alpha layer (simply click the 'Add new layer' button) and paint it white.
After this it is vital that the image be saved as a 32-bit BMP, this should be automatically selected if you have the four required layers (Red, Green, Blue, Alpha), but double check when saving it anyway.
