Imaging with free Macrium
Page 27 of 179 FirstFirst ... 17252627282937127 ... LastLast
  1. Posts : 10,455
       #260
    whs said:
    Keith, was just thinking. How did you actually produce this tut without an active system.
    VirtualBox.
  2. whs
       #261
    Smart, I should have thought of that myself. I only run Ubuntu in vBox and was considering the run the Win8 Beta that way. But maybe I put it on the HDD because I do not have a lot of room on my M4.
  3. Posts : 10,455
       #262
    Thanks Wolfgang. I've usually got a Win7 VM for things like that.
  4. Posts : 40
    Windows 7 Ultimate 64bit
       #263
    i have few questions about "Imaging with free Macrium".
    the macrium program creates an image of the os partition(C:) at a particular 'point' of time and we can bring our sytem back to that 'point' whenever we want, using this program. after restoring it does not affect any other partition and our system is just like it was at that 'point'.
    am i right?
    and is this program simiar to the progra DELL DATASAFE LOCAL BACKUP ??
  5. Posts : 10,455
       #264
    am i right?
    Yes you are correct. Only the partitions you restore are affected. Everything else is unchanged.
  6. whs
       #265
    Keith gave you the answer to your first question. I am not sure what the Dell program does. It may only backup data.
  7. Posts : 40
       #266
    so does that mean i can use this to reinstall windows (if needed) ? how will it do that i mean does it "boot" like the Dell Datasafe program?
    I am using Dell Inspiron N5050...can you tell me the steps i should follow to reinstall windows instead of a clean install? i know i sound too much confused. clear my doubts pls. thanks.
  8. Posts : 40
       #267
    DELL DATASAFE uses the "recovery" partition to restore the computer to the factory state.
  9. Posts : 10,455
       #268
  10. whs
       #269
    I suggest you follow the tutorial.
