Imaging with free Macrium
Page 62 of 179 FirstFirst ... 52606162636472162 ... LastLast
  1. Posts : 10,455
       #610
    We have a tutorial for that. Clean Install Windows 7
  2. whs
       #611
    If you install with your original OEM disc, you may get a lot of crap on it. If you have a retail disc, that is not the case.
    For the OEM case, I recommend to download a clean .iso from here: Dell Community
  3. Posts : 7
    Excellent WHS! Thanks for the link. Heading over there now to download
  4. Posts : 12,177
       #613
    Dell use to be good, the OEM OS disk was clean, no bloatware. Not sure if they are still that way.
  5. whs
       #614
    Dave, it's not too bad on my Dells. But Toshiba and Sony are really bad.
  6. Posts : 7
    Once I get the new drive installed and up and running with Win7, would you recommend taking an image before loading any programs? Perhaps this isn't worthwhile? Perhaps it is?
    I do a lot of design and development worth and have around 40 programs that i use regularly!
    Just wondering if you experienced imagers have any advice
  7. Posts : 10,455
       #616
    It may be worth taking an image after all updates have been applied. The last time I applied updates to a new system took longer than the install.
  8. Posts : 7
    Yes, that makes sense; that's what I'll do. Once I get all the programs loaded I'll take an image straight away. Thanks
  9. Posts : 10,455
       #618
    I was thinking more of Windows updates than programs, but if you have a core set of programs it makes sense to install those also.
  10. whs
       #619
    When you install a program, a system restore point is automatically created (if you enabled system restore). You can always fall back to that - if it does not mysteriously disappear.
    I would just make an image twice per week or so.
