Imaging with free Macrium
Page 72 of 179 FirstFirst ... 62707172737482172 ... LastLast
  1. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #710
    You hardware, CPU and RAM along with the HDD and its cache will have a big part in how long the restore or image creations takes. Mine take around 13 minutes on both operations. My OS image is 18GB and Data 34GB.
  2. Posts : 3,133
    Windows 7 Home Premium 64bit SP 1
       #711
    What sort of performance do you get when using an external USB HDD?
    I have images backed up on 3 separate HDD's. The first is an internal HDD I use to save data on and which I used to restore the image from, the second is using e-SATA docking station and the third is using a USB 3.0 docking station. I can save a full image on all three HDD's between 3 minutes 25 seconds and 3 minutes 45 seconds. The slowest one being when I use the USB 3.0 device. I haven't tried restoring from either external HDD dock, but only from the internal HDD, which is a SATA III connection. I may have to try it again and see what happens using one of the other drive and hopefully I will get better performance. With Windows System imaging I can do a complete 22 Gb restore to my SSD in about 10 minutes, or less, so I thought it was strange that Macrium took so long.
    Thanks to everyone for their replies!
  3. whs
       #712
    On one system I have a USB3/SSD setup. Restore for a 22GB image takes about 15 minutes.
  4. Posts : 11,840
    64-bit Windows 8.1 Pro
       #713
    Something doesn't sound right ... I just made a 24gb image and it only took 7 minutes..
  5. Posts : 9,600
    Win 7 Ultimate 64 bit
       #714
    Were you imaging to an internal drive or external? Was the destination drive SSD or HDD?
  6. Posts : 3,133
       #715
    That sounds about right to me.
    One thing I just thought of that may have made a difference. The image I restored was taken from my Samsung SSD and restored to a Kingston SSD. The total available space on the Samsung is about 2 Gbs larger than on the Kingston, so it would have needed to be resized to fit.
    Thanks for all replies!
  7. Posts : 7,466
       #716
    ICit2lol said:
    Wolfgang I have selected the rescue for the Windows ISO and gone through the instructions and insert a disk (DVD) and it goes for two seconds and then ejects it with this message. If I am doing something wrong can you please advise. I have tried 6 different empty disks soi don't think it is the media.
    John
    PS Meant to mention the image went fine:)
    I backed mine up on a usb stick it was quick and made a disk
  8. Posts : 3,133
       #717
    Just finished doing another image restore and this time it only took 3 minutes to complete. But this was restoring an image that was created from the same SSD, so it didn't have to do any resizing.
  9. mjf
    Windows 7x64 Home Premium SP1
       #718
    It still sounds odd to me unless Macrium does a full clean prior to a resize. In principle going from a smaller to a larger SSD would give some unallocated space which should be easily and quickly recovered.
  10. Posts : 1,002
    XP Pro (x86) | 7 HP (x86) & (x64) | 7 Pro (x64)
       #719
    Thank you "whs" for this excellent tutorial :)
    ... and SIW2 for the BartPe plugin, tip :)
    Found this tutorial at bottom of Macrium Free vs Macrium Pay. I have always assumed (until 2 months ago) the only cure for a sick PC was a clean install and days of reinstalling apps and custom settings.
