Imaging with free Macrium
Page 86 of 179 FirstFirst ... 76848586878896 ... LastLast
  1. Posts : 16,163
    7 X64
       #850
    Nice idea about using the SD. Doesn't seem a way to make it work.
      My Computers
  2. Posts : 1,568
    Windows 8.1.1 64bit
       #851
    Everything in my disk management then, will be backed up at one time ?
    Do I need to backup all of it ?
  3. whs
       #852
    The funny thing is that I could not find a boot.wim on my 32bit Macrium. Just the one for the PE.
    I have sent a mail to Macrium with the question whether the 32bit program can produce a bootloader entry for 'Recovery from Windows Boot menu' - that is one of the options in the paid version. I have also asked how they do that if there is no boot.wim - just to make sure.
  4. whs
       #853
    The system partition I backup once and stick it into a safe place. That you usually do not have to recover.
    The recovery partition I do not backup. The same with any tools partition they may have.
    The C partition and the data partition I backup often. For C, after an update or new program installations. For the data when I think I have changed enough to warrent an update.
    I also keep at least 10 restore points on C and on the data partition. From those I can also recover data with Shadow Explorer. That is useful for the in-between images time.
    ShadowExplorer - Recover Lost Files and Folders
  5. mjf
    Windows 7x64 Home Premium SP1
       #854
    We all have different views. If you want to remain with the OEM system then I recommend making at least one image of all your non data partitions. This includes factory recovery/restore and tools partition if present. Store these away and you can always restore to a new HDD if your old one fails. There are other options for backing up data partitions.
  6. Posts : 10,455
       #855
    The problem with imaging a data partition is thay it can be very large. You will be better off Using a file synchronization tool such as Syctoy or FreeFileSync. I also prefer the latter. They are both free. The link to FreeFileSync is in my sig.
  7. whs
       #856
    Agreed, if the data partition is very large - e.g. tons of videos - then a sync program is a better option. The problem I have with sync is that I do not fully trust it - but that may be just me.
  8. Posts : 10,455
       #857
    If you set it up a one way mirror with versions it should be safe. Synctoy cant do that but FreeFileSync can.
  9. whs
       #858
    That sounds like a good idea. I shall try that. Thanks Keith.
  10. Posts : 10,455
       #859
    My video is a bit old but may help...
    The main difference is in versioning. You now need to use a "macro" to date the version.
