Taskbar - Use Small or Large Icons
    How to Use Small or Large Icons on the Windows 7 Taskbar
    This will show you how to set the Windows 7 taskbar to display with either small or large icons.
       Tip
    Microsoft has made available a hotfix that will resolve a problem where the taskbar customizations are lost and reset to defaults when automatic logon is enabled in Windows 7 and Windows Server 2008 R2. More details are available at FIX: The Taskbar is reset to the default settings when you use the "Automatically Log On" feature in Windows 7 and in Windows Server 2008 R2.
    EXAMPLE: Taskbar with Large Icons
    EXAMPLE: Taskbar with Small Icons
    OPTION ONE
    Through Taskbar Properties
    1. Right click on a empty space on the taskbar and click on Properties.
    2. To Use Small Icons on the Taskbar
    A) Check the Use small icons box. (see screenshot below step 3A)
    B) Go to step 4.
    3. To Use Large Icons on the Taskbar
    A) Uncheck the Use small icons box. (see screenshot below)
    4. Click on OK. (See screenshot above)
    OPTION TWO
    Using a REG file Download
    1. To Use Small Icons on the Taskbar
    Small_Icons_for_Taskbar.reg
    B) Go to step 3.
    2. To Use Large Icons on the Taskbar
    Large_Icons_for_Taskbar.reg
    3. Click on Save, and save the .reg file to the desktop.
    5. Click on Run, Yes, Yes, and OK when prompted.
    6. Log off and log on, or restart the computer to apply.
    7. When done, you can delete the downloaded .reg file if you like.
    OPTION THREE
    Manually in Registry Editor
    1. Open the Start Menu, then type regedit in the search box and press Enter.
    3. In regedit, navigate to the location below. (see screenshot below)
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
    4. In the right pane of Advanced, right click on TaskbarSmallIcons and click on Modify. (see screenshot above)
    5. To Use Large Icons on the Taskbar
    A) Type 0 (number zero), and click on OK. (see screenshot below)
    B) Go to step 7.
    6. To Use Small Icons on the Taskbar
    A) Type 1, and click on OK. (see screenshot above)
    7. Close regedit.
    8. Log off and log on, or restart the computer to apply.
  1. Posts : 2
    I dislike large icons but wish to view the date. Any way to that?
  2. Posts : 8,476
    Windows® 8 Pro (64-bit)
    I guess the date can be seen in both large and small icons.
    What exactly do you want?
  3. Posts : 18,404
    No, it can't. If you use large icons which is the big taskbar it will show the date under the clock all the time, if you use small icons which is the small taskbar, it will only show the clock. But you can mouse over the time and it will show the date.
    He wants to use small taskbar but have the clock show as well as the date without mousing over the clock. I don't think you can have both. You can use a date/time gadget.
  4. Posts : 656
    Windows 7 RC build 7100x64 // 7260x32
    I have both the time and date with small icons??
    Screenshots here
    Taskbar - Use Small or Large Icons-capture.jpg Taskbar - Use Small or Large Icons-capture2.jpg
  5. Posts : 18,404
    Well yes, but your taskbar is still big. It's not like this, which is what he probably is using. But I guess we'll find out from him or not if he doesn't care about the size of the taskbar, and just the icons. :)
  6. Posts : 656
    I know its not as small as yours that is only cos the time and date pushes it up more but still using small icons
    in your other post you were saying that you cant use small icons and still show both time and date.. unless im mistaken?
  7. Posts : 18,404
    I took the assumption he wants to use the small taskbar and not the big one. You can't get the date and time to both show on the small taskbar, can you? Maybe I should of gave a better explanation in my original post. But like I said, we'll find out if he doesn't care his taskbar is big and just wants small icons, regardless of the size of the taskbar.
  8. Posts : 656
    Your right
    Small task = small icons (time only)
    big task = small icons (or big) with both time and date
  9. Posts : 20
    Win7 Ultimate 32bit
    nice 1..
    I too don't like the large icons here !
