Task Manager - Add or Remove Columns
    How to Add or Remove Columns in Task Manager in Vista and Windows 7
    This will show you how to add or remove columns in the Processes, Networking, and Users tabs in the Windows 7 or Vista Task Manager.
    All Changes made will be remembered for when you close and open Task Manager until you make new changes.
    Here's How:
    1. Right click on a empty space on the taskbar and click on Task Manager, OR press CTRL+SHIFT+ESC.
    2. To Add or Remove Columns in the Processes Tab
    A) Click on the Processes tab, then click on View (menu bar) and Select Columns. (see screenshot below)
    NOTE: The sceenshot below shows the added Base Priority (Base Pri) column added.
    B) Check or Uncheck the boxes to add or remove the available columns of your choice, then click on OK.
    3. To Add or Remove Columns in the Networking Tab
    A) Click on the Networking tab, then click on View (menu bar) and Select Columns. (see screenshot below)
    4. To Add or Remove Columns in the Users Tab
    A) Click on the Users tab, then click on View (menu bar) and Select Columns. (see screenshot below)
    5. When finished, you can close Task Manager.
  1. Posts : 11,990
    Windows 7 Ultimate 32 bit
    Another good tutorial, Shawn. Thanks once again.
  2. Posts : 72,058
    Thank you Carl. :)
  3. Posts : 11
    7 64
    Before a few days i used to get that picture when i started task manager and it showed all programs running. NOw i don't get that picture when i start task manager but only no choices. But only this
    | User | ID | Status | Client Name | Session
    zmth 1 Active Console
    and that is it ! Never any different . Used to get the window you show. I wish there was a way to upload an image on this forum but there is NOT. Don't know how you all uploaded that picture of what your screen showed. Anyway it does NOT show "Windows Task Manager" at top . NO colums with "Applications ,Processes,Services,Performance...etc. That does NOT appear but only as i have shown above.
  4. Posts : 72,058
    Hello @zmth, and welcome to Seven Forums.
    The tutorial below can help show you how to upload and attach an image to your post.
