Show Window Contents or Outline While Dragging
Page 3 of 3 FirstFirst 123
  1. Posts : 72,099
       #20
    In that case, see if toggling your original account to a local account, then back to a Microsoft account may make it work properly in it again.
    Local Account - Switch to in Windows 8
    Microsoft Account - Switch to in Windows 8
  2. Posts : 3
    Windows 8 64bit
       #21
    This is sooo randomic!
    Here's what happened:
    I followed those two tutorials. It didn't work, the problem was stil there.
    So I said myself "let's try to set the other account as a local one and see what happens!"
    So I log in that other account (which is still another Microsoft Account) and the problem appeared there before I could do a thing!
    I didn't modify anything, and it appeared...
    So I did immediatly log out and re-log in on my usual account, and now the problem doesn't show...
    It makes no sense to me!
    What should I do? Hope that it won't show anymore?
    Thank you for your patience anyway!
    EDIT:
    Uhm so, I plugged in an external HD and it did it again, I had to go to performance settings, it was set on "Custom" and I had to set it again on "Adjust for Best Appearence". I tried to simulate it again (unplugged the HD, replugged it in) but this time it did not trigger the glitch.
    I don't know if this can help... (I didn't log out/restart my laptop this time) !
  3. Posts : 72,099
       #22
    Odd glitch there Fieromuso, but glad to hear that you got it narrowed down to be able to stop it.
  4. Posts : 514
    Windows 7 Pro x64
       #23
    I just want to say thanks for this great tutorial; I have referred to it on a number of occasions.
    Here is my most recent episode(s) with the situation:
    "Show Window Contents while Dragging" somehow got turned off ???
    I will add this: in my Control Panel, instead of "Performance Options", it says "Performance Information and Tools"; I clicked that and there was "Adjust Visual Effects" at the top of the left pane.
    Thanks again.
