Context Menu - Add Empty Folder and Subfolders
    How to Add "Empty Folder and Subfolders" to Context Menu in Windows
    This tutorial will show you how to add Empty Folder and Subfolders to the context menu to be able to automatically permanently delete all file contents of a folder and it's subfolders without deleting the subfolders in Vista, Windows 7, and Windows 8.
       Warning
    Be careful of what folder you decide to empty. The files deleted by this are permanently deleted and not placed in the Recycle Bin.
    EXAMPLE: Context Menu with "Empty Folder and Subfolders" added
    Here's How:
    1. To Add Empty Folder and Subfolders
    NOTE: This will add Empty Folder and Subfolders to the context menu to automatically permanently delete the file contents of a folder and it's subfolders when used.
    A) Click on the Download button below to download the
    Add_Empty_Folder_and_Subfolders.reg file below.
    B) Go to step 7.
    2. To Add Empty Folder and Subfolders with a Prompt
    NOTE: This does the same as step 1, but will prompt you to type Y or N in the command prompt to approve each file before it is permanently deleted.
    Add_Empty_Folder_and_Subfolders_Prompt.reg file below.
    B) Go to step 7.
    3. To Remove Empty Folder and Subfolders
    NOTE: This will remove Empty Folder and Subfolders (step 1 or step 2) from the context menu.
    Remove_Empty_Folder_and_Subfolders.reg file below.
    B) Go to step 7.
    4. To Add Empty Folder and Not Subfolders
    NOTE: This will add Empty Folder and Not Subfolders to the context menu to automatically permanently delete the file contents of only the selected folder and none of it's subfolders when used.
    Add_Empty_Folder_and_Not_Subfolders.reg file below.
    B) Go to step 7.
    5. To Add Empty Folder and Not Subfolders with a Prompt
    NOTE: This does the same as step 4, but will prompt you to type Y or N in the command prompt to approve each file before it is permanently deleted.
    Add_Empty_Folder_and_Not_Subfolders_Prompt.reg file below.
    B) Go to step 7.
    6. To Remove Empty Folder and Not Subfolders
    NOTE: This will remove Empty Folder and Not Subfolders (step 4 or step 5) from the context menu.
    Remove_Empty_Folder_and_Not_Subfolders.reg file below.
    7. Save the .reg file to your desktop.
    8. Double click/tap one the downloaded .reg file to merge it.
    9. If prompted, click/tap on Run, Yes (UAC-Windows 7/8) or Continue (UAC-Vista), Yes, and OK when prompted.
    10. When finished, you can delete the downloaded .reg file if you like.
  1. Posts : 12
    Wow...good job
  2. Posts : 1,065
    Is there anyway to send the files to the recycle bin first?
  3. Posts : 72,062
    Hello Stu,
    Not that I know of. Other than manually deleting them, step 2 is about the closest option to at least prompt you before deleting them.
  4. Posts : 1,065
    Nevermind, still a very handy tweak , thanks a bunch :)
  5. 24c
    Win7 x64 Ult
    Thanks, just what I have been looking for.
  6. Posts : 1,065
    Shawn, how would one go about modifying this to become a context menu item to just empty the folder and not empty the subfolder too?
    TIA :)
  7. Posts : 72,062
    Hello Stu,
    No problem. Steps 4, 5, and 6 added just for this. :)
  8. Posts : 1,065
    Brink said:
    Hello Stu,
    A true gent, thank you :)
  9. Posts : 72,062
    You're most welcome Stu. :)
