Disk Cleanup : Extended
Page 7 of 10 FirstFirst ... 56789 ... LastLast
  1. Posts : 25,847
       #60
    I'm confused. I type in the search (disk) right click (send to desktop shortcut). Do I get the same disk cleanup as the extended?
  2. Posts : 22,814
    W 7 64-bit Ultimate
       #61
    Have a look at this section of the tutorial.
    To add a shortcut to the desktop.
  3. Posts : 25,847
       #62
    I have a shortcut on my desktop. What I'm trying to find out, is the disk cleanup you folks are getting to with bat. files, notepad any different than using the method I used in my post #60 or is it just another way to get to disk cleanup?
    Is extended disk cleanup and different than just plain disk cleanup?
  4. Posts : 22,814
    W 7 64-bit Ultimate
       #63
    Yes there is a big difference, compare the 2 for yourself.
  5. Posts : 25,847
       #64
    I will give it a try, thank you.
  6. Posts : 22,814
    W 7 64-bit Ultimate
       #65
    Be sure to post back here with your comments on the 2 separate methods.
  7. Posts : 25,847
       #66
    IMHO the extended does do a deeper cleanup job. I will use it often. I haven't got the shortcut to work but no big deal, I just cut/paste from notepad.
  8. Posts : 22,814
    W 7 64-bit Ultimate
       #67
    Well done mate, thanks for the update.
  9. Posts : 7,730
    Windows 7 Ultimate SP1 64-Bit
       #68
    Thanks to the pair of you for some good work, it ran perfectly on my machine.
    I have a folder on my backup drive named Windows Batch Files and store all my batch files there.
    I also discovered that if I right-click the batch file in the location I stored it, and then choose Run As Administrator it will automatically open a command prompt window and the Disk Cleanup Settings window.
    A nice program, thanks to you both.
    I tried to +rep you both, but the system wouldn't let me.
  10. Posts : 22,814
    W 7 64-bit Ultimate
       #69
    Hello Andrew.
    I wrote the tutorial and Carl wrote the .bat file; good to see you find it useful.
    This .bat file was created by CarlTR6 credit for this goes to him!
    @Layback use the method in this tutorial to point to the .bat file to create the shortcut for the desktop.
