Disk Cleanup : Extended
Page 8 of 10 FirstFirst ... 678910 LastLast
  1. Posts : 7,730
    Windows 7 Ultimate SP1 64-Bit
       #70
    Thanks again, it's no surprise this forum is so highly thought of.
  2. Posts : 22,814
    W 7 64-bit Ultimate
       #71
    Bare Foot Kid said:
    Use the method in this tutorial to point to the .bat file to create the shortcut for the desktop.
    I just used this to create a shortcut for the desktop and it still works very well, it opens and closes all on its own, the only thing that needs done is to confirm the files you want cleaned.
  3. Posts : 168
    Windows 10 Home 64b
       #72
    Is it normal to disk cleanup extended no to show up the size of the items to be deleted?
  4. Posts : 72,062
       #73
    Yes, I'm afraid so.
  5. Posts : 1
    Windows 7 Home x64
       #74
    I'm terribly sorry to revive this old thread, but I have a question.
    Been at this for hours now, and this seems like the only solution that might work.
    When I type the command in cmd run as admin.. I get a message saying "Access denied".
    Why might this be?
    Also, no "Windows Update Cleaner" option to tick in Cleanmgr
  6. Posts : 72,062
       #75
    Hello hoofbite, and welcome to Seven Forums. :)
    It sounds like you didn't run the command in an elevated command prompt.
    (click on link) Elevated Command Prompt
  7. Posts : 476
    windows 7 ultimate 64bit
       #76
    hi
    great tutorial
    would be great a task scheduler that performt it always after 2 days after un update
  8. Posts : 242
    win7 Home Premium x64
       #77
    One more thanks guys, from an avid desktop shortcut lover. Jim
  9. Posts : 8
    Windows 7 Pro x64
       #78
    I love this technique, even have my clean.bat file in Dropbox and create a shortcut onto all my computers desktops
  10. Posts : 1
    Windows 7 Professional
       #79
    Be Aware of Windows Disc Cleanup (cleanmgr) Problems
    This extended cleanup method might be very dangerous because you don't see the size of the selected options. Sometimes they exceed even the size of the hard drive, which is obvious due to some registry corruption. For example, you can search the web for "huge windows error reporting files", which cleanup resulted in wiping out the entire system. On of this files, which size was supposed to be 0 KB was displayed as about 150 GB on my laptop. Can you imagine if I ran this "extended cleanup"? It would have been really extended. I also experienced a similar problem trying to delete Windows Update Files of about 4 GB, which is not unreasonable. After this the system could not restart (was hanging attempting to complete some phantom windows updates) and was severely corrupted (restore points were gone) so only recovery disk helped. And this exact incident happened two times on my laptop.
    So, please, keep this in mind while running this "extended blind cleanup".
