#30
Hey, for you registry editing folks, create a raw (no word wrap) text file with the following lines:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment]
"DEVMGR_SHOW_DETAILS"="1"
"DEVMGR_SHOW_NONPRESENT_DEVICES"="1"
Save it as SomeFileName.reg and double-click to merge into the registry.
Or you can use the attached reg file to double-click it and merge it into your registry.
Note: You will still have to click View -> Show Hidden Devices when in Device Mangler.
HI,
I just replaced the contents of the PATH in the environment variables, can you please gv info abt resetting it to its prev value???Please help me ...
Yes, a system restore using a restore point dated before he deleted the contents should be able to restore them. :)
will there be any modifications to my data including deletion ?????? after restoring..............
Hello Misty,
Any installed programs, changes made to system files, and changes made to the registry will be restored back to how they were at the date the restore point was created. User files and data will not be affected. :)
System Restore
