Device Manager : Hidden Devices
Page 1 of 5 123 ... LastLast
    How to View Hidden Devices in Windows 7
    How to Show and Access Hidden and Ghost Devices and Drivers in Device Manager
    This will show you the devices and drivers from programs you no longer use, it will free up some disk space, not to mention help resolve potential conflicts between drivers that are no longer needed.
       Warning
    You do not want delete any Generic Volume Shadow Copy Drivers or Non-Plug and Play Devices before you make sure of their functions as you could disable the PC entirely or at the least some programs / apps will fail to function.
    Let's get started!
    1) In the Windows 7 start menu right click computer and select properties, in the "System" window that opens in the upper left pane select Advanced System Settings.
    Device Manager : Hidden Devices-properties.jpg
    Device Manager : Hidden Devices-devices2.jpg
    2) In the system properties window that opens under the advanced tab select the Environment Variables button, in the Environment Variables window select new, then in the New User Variable window type "devmgr_show_nonpresent_devices" (without the quotes) and give it a value of " 1 " then click ok to add the entry, then ok again to finish.
    Device Manager : Hidden Devices-devices3.jpgDevice Manager : Hidden Devices-devices4.jpg
    Device Manager : Hidden Devices-devices5.jpgDevice Manager : Hidden Devices-devices6.jpg
    3) Again in the Windows start menu right click computer and this time select manage, in the window that opens in the left pane select Device Manager, at the top click view and select Show Hidden Devices.
    Device Manager : Hidden Devices-manage.jpg
    Device Manager : Hidden Devices-devices8.jpg
    4) You can now see hidden / ghost drivers and devices by expanding the entry, they will be faded compared to the others.
    Device Manager : Hidden Devices-devices9.jpg
    Enjoy! :)
  1. Posts : 28,845
    Win 8 Release candidate 8400
    Excellent Tutorial and I am sure few people know about it.
  2. Posts : 22,814
    W 7 64-bit Ultimate
    Thank you Ken! :)
  3. Posts : 11,990
    Windows 7 Ultimate 32 bit
    Thanks much. I had done this in XP and I had forgotten about it. Excellent tutorial. +1
  4. Posts : 22,814
    W 7 64-bit Ultimate
    Thanks Carl! :)
  5. Posts : 17,322
    Win 10 Pro x64
    Way to go Ted, Great Tutorial. Very Helpful, Thanks.
    Derek
  6. Posts : 22,814
    W 7 64-bit Ultimate
    Thank you Derek! :)
  7. NoN
    I used to do it on XP and was the first thing i did on Win7...
    DEVMGR_SHOW_DETAILS, set to 1
    DEVMGR_SHOW_NONPRESENT_DEVICES, set to 1...
    Good remind to get rid of ghost devices!
  8. Posts : 22,814
    W 7 64-bit Ultimate
    Hello NoN, I'm glad you find it useful.
  9. NoN
    Hi, yes of course!
    That's pretty handy when many devices had been plugged onto the computer...then, if you do not need them anymore, it free the place for other one!:)
